Author Topic: cutting circles in clear plastic for windows  (Read 7892 times)
wallace
« on: February 05, 2009, 07:17:52 pm »
whats the best way to cut clear plastic for windows and portholes.    wallace
Re: cutting circles in clear plastic for windows
« Reply #1 on: February 05, 2009, 08:00:50 pm »
Depends on how big you need them. A revolving leather punch works well for small sizes and on thin plastic or you can go for a hollow punch tool set like this: http://openoffice.3-suite.com/index.asp?aff=105&camp=gg_op_uk&se=google
boatmadman
« Reply #2 on: February 05, 2009, 10:06:23 pm »
I have had success using a short piece of brass tube-the inner dia to suit the disc dia you need. Sharpen the tube on the outside to the inside, and punch out the material on the end grain of a pce of wood.
wallace
« Reply #3 on: February 06, 2009, 10:04:53 am »
Thanks Ian  what a good tip will have to get some brass tubing  its for my port holes what about the windows I always cut then sand down   wallace
craftysod
« Reply #4 on: February 06, 2009, 03:37:53 pm »
Hobby shops do a circle cutter,it looks like a compass,but where the pencil lead goes there is a blade.
Not sure how small they cut tho
Mark
« Reply #5 on: February 06, 2009, 03:40:56 pm »
Yes, I bought one but it's only good for fairly large circles. For porthole glass a punch is usually the best bet. I have a heavy duty single hole one intended for punching holes in documents to go in ring binders and it gives great results.
Arrow5
« Reply #6 on: February 06, 2009, 05:10:44 pm »
I`ve never tried it but how about perspex or similar clear rod sliced into discs and the surfaces polished to get rid of saw-cuts ? {:-{ :embarrassed:
..well can you land on this?
wallace
« Reply #7 on: February 06, 2009, 07:32:39 pm »
Many thanks for your reply and your tips
   wallace
craftysod
« Reply #8 on: February 06, 2009, 07:39:08 pm »
Wallace,if you have a pound shop near you,they do a set off round hole punches for a couple of quid.
wallace
« Reply #9 on: February 06, 2009, 07:44:29 pm »
thanks alot and yes in Birkenhead will go down next week and have alook.
                wallace
dave301bounty
« Reply #10 on: February 06, 2009, 08:34:36 pm »
Wallace,  have you sorted your rivet thing yet ,i am coming over on sunday ,about 3 ,can i help ,because i will have a passenger who knows a lot more than me ,.talk about port holes how about a tube the sixe you want ,warm it and score ,,lets know ,and i will pop in sunday ..dave .
More Coffee
« Reply #11 on: April 25, 2009, 01:43:30 am »
I use a Gasket Hole punch set... has variuos sizes fron 1/8 up to 7/8 ... I lay the material out on 5/8 MDF when punching ..They also work decent to punch holes through 1/16 up to 1/8 plywood..
Microyacht
« Reply #12 on: September 21, 2009, 08:16:33 pm »
How about bigger windows? I need four @ 2" diameter and four @ 1" in diameter! They are for a large catamaran!
Steve
http://www.microcat.co.uk
Bryan Young
« Reply #13 on: September 21, 2009, 11:23:30 pm »
Scissors.BY
Notes from a simple seaman
Microyacht
« Reply #14 on: September 21, 2009, 11:28:31 pm »
My hands are not that steady!
Might stick a bit of plastic on a faceplate and try and cut them on my Lathe!
Steve
dodgy geezer
« Reply #15 on: September 21, 2009, 11:55:11 pm »
Scissors is fine.
For large windows I:
- draw the shape on paper
- sellotape that to the plastic
- cut round it as accurately as I am able
- finish off cutting by fileing the edges down to an exact fit with the paper drawing. If a file is too slow, use a small sanding drum on a minicraft. This can make precise and complicated shapes quite quickly. Make sure the selotape supports the paper when it is cut to the line, though...
for small portholes, particularly on plastic hulls, I discard the plastic glazing, mix some clear epoxy and drop that in the hole. Surface tension holds it flat for diameters up to about 1/4", and it's much clearer and smoother than typical plastic sheet. As well as being waterproof...
BarryM
wallace
« Reply #17 on: September 23, 2009, 07:22:23 pm »
Thanks for all the replys most welcome in the end I cheeted and got them with the port holes any way tips always help.
                     wallace
Page created in 0.17 seconds with 17 queries.
