Author Topic: White Metal Fittings  (Read 4780 times)
« on: February 08, 2009, 10:55:04 am »
I am scratch building a 1:48 scale coastal steamer similar to the old Ben Line ships and I need some white metal mast and derrick fittings.
Anyone know where I can get them other than kit manufacturers ?
nhp651
Re: White Metal Fittings
« Reply #1 on: February 08, 2009, 12:50:31 pm »
you can buy most of those fittings as single purchase, dick, from caldercraft/jotika.
at shows they have them all laid out in display boxes for a few pence a fitting.
neil. :-))
« Reply #2 on: February 08, 2009, 01:03:40 pm »
Thanks Neil, will give them a try.  ok2
« Reply #3 on: February 17, 2009, 09:20:15 am »
Right, I rang Jotika on the 8th February to request some information on these fittings, they said they would send me a list.
I rang again today to be told they had not sent it yet.
Does anyone know where else I might get these fittings ? Mainly for masts and derricks.
« Reply #4 on: February 17, 2009, 09:58:08 am »
Have you tried Mobile Marine Models Richard? I bought some blocks from them a week or two ago, came within a couple of days.
http://www.mobilemarinemodels.com/acatalog/Fittings.html
« Reply #5 on: February 17, 2009, 10:23:15 am »
Reckoned to get pulleys from them Colin but what I am stuck for is the actual mast and derrick bands and the hinge bit at the bottom of the derrick where it meets the mast.
« Reply #6 on: February 17, 2009, 11:02:29 am »
You could use thin strips of gumstrip paper to make the mast bands, it contracts slightly as it dries. The a bit of sanding sealer or similar before painting. Heads of thin split pins or loops with a tail from thin brass wire will provide the the attachment loops. As far as the hinge is concerned, unless it has to take a strain, you could simply try knocking it up in plasticard.
« Reply #7 on: February 17, 2009, 11:04:05 am »
 Hi  Dicky this may help  :-))
john
bluebird
« Reply #8 on: February 18, 2009, 07:38:06 pm »
Hi ya there Richard,
I was supposed to put these couple of pictures on yesterday, but you know these senile moments where you get distracted and forget all about it; well, anyway, there is a picture of the 'derrick' from the Morray Forth - for this one you will see I made the bands from copper wire; bent round a suitable sized tube clipped off to the correct diameter, soldered and then superglued onto the end of the derricks.
The other couple of pictures are the masts of the Frederique Spashett and this is where you will see I have used the brass bands which I cut from tube of the appropraite diameter with a tube cutter and attached various bits of copper wire to form the loops and the eye-bolts and soforth.
aye
john
Page created in 0.016 seconds with 22 queries.
