Hi there, I'm new to this site, and was trawling (forgive the maritime pun) for info about life boat models. More of that later, but re your query about motors:-
I have sitting here in my hotsweaty hand a blower motor from (I have reason to believe a Renault) a motor made by Siemens. Their part number is 1BB 3224 also marked on the case it says 8-13 volts. size, 45mm diameter (about 3/8" under your critical 2") length 83mm minus out put shaft. The out put shaft is 6mm diameter by 16mm. Unusually the brushes are mounted at the out put shaft end.
I am about to fit a pair of these into a life boat model (1/12 scale solent class) to see if it will push this at scale speed (about 1 1/2 knots actual).
As yet I do not have any data on the current draw or rotational speed, but I would imagine that over powering these motors by upping the voltage would be no problem if you could ensure a good air flow (they are very "open" at front and rear and should allow plenty of air flow through them.
Hope this may be of some use to you
in the meantime I'm looking for info and pics on the solent class life boat, in particular the Mumbles lifeboat (Swansea). I believe (but am happy to be corrected) that after service here in south wales it went o Loch Inver where it became named the "george Uri Scott" any ideas?
I will be posting this enquiry elsewhere in the forum, but would be greatful if you know of anyone out there with any info you could pass this on to.
Thanks d-jnana (Gary)
