Author Topic: Pressure gauge for gas burner  (Read 3202 times)
monarch
« on: February 18, 2009, 03:20:08 pm »
I have read with interest the usefullness of having a pressure gauge on the feed line from tank to burner.
But where do I put the gauge if a gas regulator is fitted, on the input or output of regulator and depending on position what max pressure gauge do I use.
Bunkerbarge
Re: Pressure gauge for gas burner
« Reply #1 on: February 18, 2009, 04:17:41 pm »
If you look at the Paddleducks site there was a lengthy discussion on this not so long ago which also continued on here as well.
Basically what do you want it to tell you?  If you are interested in the pressure of the tank as well as when it is empty then you want it before the regulator but if you want to ensure that the gas pressure at the burner is remaining constant and therefore that the regulator is doing it's job then you want it after the regulator.  There will be some who advocate both!!
My gauge is on the tank itself as my main concern is whether the cooling effect due to evaporation is becoming excessive and affecting the tank pressure.  If this was to drop off enough and become lower than the set point of the regulator then it would also affect the burner pressure.
As for the range, that was where the lengthy discussions came into it but these concerns would only be relevent if the gauge was on the tank.
Page created in 0.223 seconds with 15 queries.
