Author Topic: How to Build a Springer Tug  (Read 10528 times)
Voodoohydro
« on: February 27, 2009, 04:22:24 PM »
 {:-{I have a DUMB and certainly a EMBARRASING one but i would like some info on how to build a Springer. I have never built a boat from scratch. I don't no the first thing about or were to start. I guess my questions are, what type of wood, how thick and if i have plans do i trace the plans on to the wood? Just a few questions like that. Any info would help a lot, Thank You,Keith <:(
Martin [Admin]
Re: How to Build a Springer Tug
« Reply #1 on: February 27, 2009, 04:43:46 PM »
Hi Keith yes, trace the outlines on to wood and then check they are the right overall dimensions,
 ie. 18" long by 8" wide... or the nearest Metric conversion. Don't try to use too tick a wood for the hull bottom, use two layer instead.
Here mine in various stages:
http://www.modelboatmayhem.co.uk/My_models/Springer/index.htm
toesupwa
  • USA'd ex Brit
« Reply #2 on: February 27, 2009, 04:44:08 PM »
Start here..
http://www.modelboatmayhem.co.uk/forum/index.php?topic=3471.0
Or here..
http://www.rcgroups.com/forums/showthread.php?t=522762 (this one will take you a while)
Wood: Anything from 1/4" ply all the way up to 3/4" pine.
Tracing: You could, or stick the plan to card, cut out and use the card as a template.
Any more questions, just ask!..  O0
toesupwa
  • USA'd ex Brit
« Reply #3 on: February 27, 2009, 04:52:41 PM »
Also...
Have a look at the San Francisco group.. http://sfmyc.org/index.php?option=com_content&task=view&id=23&Itemid=49 (about 2 hours from you) as they are one of the 'main' centres for Springers on the West Coast.
They have a couple of Springer meets during the year too.  :-))
chingdevil
« Reply #4 on: February 27, 2009, 05:00:59 PM »
Hi Keith
Welcome to Mayhem, as has already been said trace around the plan on to the wood, cut a little away from the mark and then sand back to it. Any other questions on Springers ask away, there has been quite a few built by forum members. I have three sitting in my shed, but I am just a beginner compared to others.
Brian
Voodoohydro
« Reply #5 on: February 27, 2009, 07:48:29 PM »
Thanks for all the info guys it's real helpful. But i have another question? Do you fiberglass or epoxy over the hull? Or just leave it alone and paint it? {:-{
craftysod
« Reply #6 on: February 27, 2009, 08:10:08 PM »
I have used waterproof varnish(3 coats),to seal the hull,then paint on top.
Remember to rub down between coats,to act as key for the next coat.
There are plenty of wood sealers availiable
Mark
Arrow5
« Reply #7 on: February 27, 2009, 08:12:38 PM »
It is a matter of choice , no fixed methods. If you are going to build a lightweight version useful weight and strength will by gained by glassing it. Most people I guess will settle for paint only.  Some hulls are all glassfibre, at least one commercially available in the USA.  No rocket science required. Your handle includes "hydro" if that is as in Hydroplane then Springers aint. Get started it`ll work no matter what route or material you use.  Most of mine are recycled wood, no two built the same .  As far as the build goes it is "Formula Libre"   Do a standard regs (motor etc) one first, no point in super motors  until you see what a basic one does on the water.  Most value for your  $$$$ in model boating IMHO. Good luck and keep us posted. :-))
..well can you land on this?
craftysod
« Reply #8 on: February 27, 2009, 08:30:57 PM »
Duncan,
Got mine finished (sort of) today,put in bath for power test,nearly emptied the water,and fast or what.
Will take to pond sunday,give it sum,post pics monday.
Got the bug and built a barge for it to push/pull,a pic of it now and barge top
Mark
Voodoohydro
« Reply #9 on: February 27, 2009, 10:54:01 PM »
Great Thanks again guys for the Info, sure helps. Nice boat Craftysod can't wait to see the pics in the water.  And ARROW5 yes i do race Hydroplanes and Tunnels but just thought i mite slow down a bit.LOL {-)
Thanks again..Keith
Voodoohydro
« Reply #10 on: February 27, 2009, 11:59:12 PM »
Thanks again..Keith {-)
P.S. What scale are these Boats?
Umi_Ryuzuki
« Reply #11 on: February 28, 2009, 12:30:33 AM »
The scale of springers is... well, 1.8m(6 ft) is the height of your pilot figure, or
 maybe 2.1m(7 ft) to the top of the door. A lot of people scale them to about 1/18 or 1/24.
Mine is scaled at 1/60
Voodoohydro
« Reply #12 on: February 28, 2009, 02:44:12 PM »
Thanks for the info UMI_RYUZUKI I like your boat, i really like the PILOT HOUSE with all the windows, did you make that from scratch? Looks good.
Thanks again, Keith
Arrow5
« Reply #13 on: February 28, 2009, 06:23:19 PM »
Got the barge finished yet  Crafty ? %)
craftysod
« Reply #14 on: February 28, 2009, 06:45:40 PM »
Voodoo,you have not seen some of Umi's work,she is a exemptional (spelt wrong) builder,and is all scratch built.
The barge will be on the water next weekend,swmbo had other plans for me to finish it off today
Mark
Umi_Ryuzuki
« Reply #15 on: March 01, 2009, 07:23:01 PM »
Thanks Keith,
Yes, like all springers, this one is all scratch built.
Springers are good models to practice construction techniques.
Here are a couple process pics of the pilot house.
gingyer
« Reply #16 on: March 01, 2009, 07:24:51 PM »
Umi
can you give some more info on the consoles and how you lit them up
thay look superb :-)) O0
Voodoohydro
« Reply #17 on: March 01, 2009, 08:30:33 PM »
Thanks Umi, thats great, helps a lot. I love that consoul and radar screen you have in there I assume thats scratch built? From the looks of things your a true Master!
Thanks again for the help.  Keith :-))
bosun
    • bosunsmodelboats.com
« Reply #18 on: March 01, 2009, 08:34:08 PM »
Gingyer
Have  a look at the  Hints and Tips section, re how to install Fibre Optics
Bosun
gingyer
« Reply #19 on: March 01, 2009, 08:43:16 PM »
thanks Bosun
that has given me some food for thought :-))
Umi_Ryuzuki
« Reply #20 on: March 01, 2009, 09:46:03 PM »
I have been selling the 1/60 scale console to those that think they can use them.
The monitors are coming out okay, but not consistently. They sometime have
air bubbles in the castings. You can see the Master, and clear castings here.
I have also worked up a console top for 1/32nd scale.
It's up to the builder to either make a rectangular, or cut the corner
and make a beveled console top. Approximately 19mm x 28mm
The rabbet channels on the bottom allow the console top
to sit on 1.5mm thick wood or styrene cabinet sides.
gingyer
« Reply #21 on: March 01, 2009, 09:51:51 PM »
very nice umi, VERY NICE  :-))
bosun
« Reply #22 on: March 01, 2009, 11:52:52 PM »
Hy Umi
I have  had a look on your site, but cant find the 1/32 consule, are you marketing them yet, or are they in the pipeline to be marketed.
 Cheers Bosun
Umi_Ryuzuki
« Reply #23 on: March 02, 2009, 12:24:30 AM »
Hy Umi
 Cheers Bosun
They're in the pipeline, I am trying to get more stuff on the webpage, I can think of a
few things that aren't on the webpage yet. Most of it is due to production factors.
The Clear pieces for the 1/32 console were a test shot in the mold, and It had a few issues.
I'm working on it...  %)
bosun
« Reply #24 on: March 02, 2009, 08:44:28 AM »
    Cheers Umi, will keep an eye on your website.
Bosun :-))
