Author Topic: I need this but not sure what is called or where I can get it. !!  (Read 1515 times)
The long Build
Many years ago My grandfather used a device attached to a blue camping gas cylinder he used to get the coal fire going more or less like a blow torch.
I am after one , Does anybody know what this might have been called and if so where I can get one from.
Larry
regiment
Re: I need this but not sure what is called or where I can get it. !!
« Reply #1 on: March 01, 2009, 06:12:58 pm »
find your local calor gas dealer he should help
catengineman
« Reply #2 on: March 01, 2009, 06:15:35 pm »
do you mean a gas poker? many years ago there was one next to the hearth in our house (gas lamp days) and dad used to relight the fire sunday morning after cleaning the back boiler with a wire brush, had kindling but no paper (that went to the lavy)  :embarrassed:
http://www.bes.co.uk/products/015.asp
Possibly like this
R.
The long Build
« Reply #3 on: March 01, 2009, 06:45:44 pm »
Possibly like this
R.
Thats the one. exactly the same as the one we had all those years ago.
Thanks for that,  yes a gas Poker , da fancy not remembering that.
Just checking out Sea Mariners link and then will order one if our local supplier does not have one.
Cheers. :-))
catengineman
« Reply #4 on: March 01, 2009, 07:01:47 pm »
You may have a little problem getting one elf n safety ! best of luck there  :-))
you could build one yourself gaz hose lance and add a little air pressure from a small compressor and there you have it your very own thurmic lance.
you only need a little air pressure to stop the flame backing up the pipe, the flame should burn just outside the lance as in a gas cutting torch.
R,
Colin H
« Reply #5 on: March 03, 2009, 04:22:08 pm »
Long build,
Hope you have noticed that the poker from BES is only for use with natural gas.
Colin H.
do every thing today tomorrow may not arrive.
tobyker
« Reply #6 on: March 09, 2009, 10:08:39 am »
You can also get an electric device like a big hair dryer which blows extremely hot air into the fire to light it. (But I'm not sure if it uses natural electricity or the old town electricity :D)
