Looks good Mick so come on what mods did you do to the motor how about a few pics of what you did for us dummies .Might even have a bash at doing some minor mods to the one i have here,but i might keep it air cooled for now as i have a boat i can run open top ,this one will be for my son .
Mart
Mart,
Apart from water-cooling the head if you do not have a lathe anybody could do the mods I have done, porting; inlet open up the port as much as possible but NOT at the top because the port must not be above the piston at BDC, the exhaust port again open up as much as possible and polish both ports. Chamfer the edges of transfer ports, inlet and exhaust inside the cylinder but NOT the top of inlet port, this will prolong the life of the engine when they are not chamfered they act as a scraper ring and take oil from bore.
Open up the carb insulator the same diameter as carb venturi, if you have one fit walbro 257 I think this would be the best for this engine I am running with 644 which I had given to me.
I also rebalanced the flywheel, I notice some vibration when first run, easy to do remove flywheel fit on a shaft the same diameter as crankshaft fairly tight fit, set up 2 parallel bars rotate slowly if the flywheel stops in the same position without rotating its ok, if it moves backwards or forwards before it stops it will rebalancing it will always rotate to bottom, the point of imbalance start with a small drill and remove a little at a time until you achieve correct balance.
I also use NGKCMR7H Spark Plug, hotter than the standard one
You can see what RPM I am getting, so there you go Mart, do you keep the original clutch, I dumped mine and fitted a flexishaft coupling which will screw straight on to crankshaft which also holds the flywheel.
Mick
