Author Topic: BEC  (Read 4186 times)
funtimefrankie
BEC
« on: March 05, 2009, 04:55:39 pm »
I understand what the BEC does when it's part of an ESC, suppling the power to the RX and servos from the drive battery, but what does it mean when a RX marked BEC, and how do you make use of it ??
andrewh
Re: BEC
« Reply #1 on: March 05, 2009, 05:06:34 pm »
FTF
It means curiously enuf that the receiver also has a voltage regulator, and can (within reason) sort out 5V for itself even if it is fed with more volts - specifically 6-cell and 7 cell buggy packs
I think it is only found on 27 MHxz receivers (in writing anyway) and I was so concerned I took mine apart and found a 7805 regulator chip - so then I believed!
So if you were running a buggy (or boat) with a 6-cell pack and 2 servos (one usually works a switch or mechanical speed controller) you can feed the full voltage into the receiver.  I am not sure what the servos get in this case, but it worked for the car lads at least till ESCs arrived
andrew
andyn
Re: BEC
« Reply #2 on: March 05, 2009, 05:15:11 pm »
Seconded. Until I got a Microprocessor ESC for one of my truggys, it had a mechanical speed control in it, and the Rx sorted out it's own power from a 7 cell Sub-C pack quite happily :-))
stallspeed
Re: BEC
« Reply #3 on: March 05, 2009, 06:21:03 pm »
The RX bec will probably be 6 volts when you feed in excess of that.
I think the BEC old Futaba receivers use a 5 amp PNP transistor.It has no overload protection.Careful how much current you draw when you feed it with greater than 6 volts.
maninthestreet
Re: BEC
« Reply #4 on: March 05, 2009, 07:52:17 pm »
FTF
andrew
The Hitec receiver that comes with the 40MHZ Ranger 2N radio system has BEC.
Robert Davies
Re: BEC
« Reply #5 on: March 18, 2009, 12:54:01 pm »
Currently, and successfully in the past, I've used one of these 'Hobbywing Switch-Mode 5V/6V 3A max 5A UBEC' and bypassed any BEC arrangement in ESCs or RXs. Especially when there is a high battery input voltage (more than 6v) or high servo loading (barn door rudder, or steering servo on a rock crawler).
-Rob
Page created in 0.015 seconds with 20 queries.
