Pages: 1 2 3 [4]   Go Down
Author Topic: Hydrafibre models still around?  (Read 29292 times)
Re: HydraFibre Models...
« Reply #75 on: October 17, 2021, 04:12:01 pm »
« Reply #76 on: October 17, 2021, 04:21:50 pm »
From my archives .... Boeing Jetfoil from Hydrafibre
KitS
« Reply #77 on: October 18, 2021, 10:58:03 am »
Coo, a scale Jetfoil!  %%
But how does it work in model form? The real thing had a very complex wave sensing radar in the bow that trimmed the bow foil to enable the boat to ride the wave profile. Plus lateral accelerometers to drive the stern foils to enable it to lean into the turns. So how do you do all that in miniature?
I rode the P&O Jetfoil from Tower Pier in London to Ostend once, and it was MOST impressive.
Kit
« Reply #78 on: October 18, 2021, 11:28:48 am »
...and do we see the date availability as  %) %) .....1st May 1986?
zooma
  • Never too old to learn !
« Reply #79 on: October 18, 2021, 09:33:39 pm »
Cor Blimey - that would be a technically advanced Jetfoil model if it had all that spec working on it  O0
tsenecal
« Reply #80 on: October 18, 2021, 10:14:32 pm »
talk to this guy:
http://rcgroups.com/forums/showthread.php?853428-Jetfoil-boeing-929
RST
« Reply #81 on: October 18, 2021, 10:40:11 pm »
Beat me to it, has a few of them now I think. He posted up. A new one a day or three ago.  Have been watching him for a while.
KitS
« Reply #82 on: October 18, 2021, 11:10:15 pm »
Looks like he built a Jetfoil and a Pegasus too, with a gyro doing some of the control work, but those posts are ten years old and there has to be better methods nowadays.
Kit
RST
« Reply #83 on: October 18, 2021, 11:49:56 pm »
...He might use a gyro but did he not post up hs latest model just under 3 weeks ago?  I was under the impression unless it's a surface peircing type like the greek gentleman posts on there, it's difficult to have a passive foil system.
tsenecal
« Reply #84 on: October 19, 2021, 04:50:37 am »
i picked that one specifically because it shows of a boeing jetfoil...  but as RST says, that guy has several hydrofoils, all of which follow the same setup, and  others on RCGroups have successfully copied his technique
Umi_Ryuzuki
    • Models and Miniatures
« Reply #85 on: October 19, 2021, 05:46:14 am »
The gyro became more trouble than they are worth, but I think two of Takahashi san's hydrofoil still use them.
On some of his latest, it is purely a mix on ailerons and rudder, with a little bit of elevator to
prevent the nose from diving as speed drops in a turn. So the models are literally flown.
zooma
« Reply #86 on: October 19, 2021, 11:57:35 am »
Nice action picture  :-))
KitS
« Reply #87 on: October 19, 2021, 04:17:06 pm »
I like that pic, that's the USN Tucumcari, one of the earliest hydrofoils.  :-))
Kit
mrzippy
Umi_Ryuzuki
« Reply #89 on: October 19, 2021, 06:48:48 pm »
Info here -
https://www.foils.org/wp-content/uploads/2017/09/Radio-Controlled-RC-Model-Hydrofoils-Power-Sail-1.pdf
Some of those posts were back in the day...  :-)
 We were experimenting and there were only nitro motors, and small brushed test beds.
My first pump was essentially a blender, no thrust. The second used a racing prop, syringes and a used nozzle.
And it was years till I realized, I was choking the jet pump because the intakes were built to scale, and
too small to provide a good intake volume, choking the performance.
Akira
« Reply #90 on: November 05, 2021, 12:33:46 pm »
"The gyro became more trouble than they are worth, but I think two of Takahashi san's hydrofoil still use them.
prevent the nose from diving as speed drops in a turn. So the models are literally flown." Aimee,I suspect that with the new computer radios, particularly something one that runs programming like OpenTx, the mixing becomes quite easy and simulates the computer controls on the 1:1 vessels, No?
« Reply #91 on: November 05, 2021, 02:59:10 pm »
I still have a Hydrafibre 1/64 Type 21 Frigate. Quite a big beast.
Umi_Ryuzuki
« Reply #92 on: November 05, 2021, 05:03:50 pm »
The Rudder/ailerons are mixed, so when the model turns, it leans in, but applying the
elevator and managing speed are still up to the operator. Takahashi-san has had a keen
interest in the old HydraFibre kit, but has been unable to find one available.
big_bri
« Reply #93 on: November 05, 2021, 06:44:52 pm »
I have one too Bob ...and a load of 1/64 fittings which are pretty rare.
Brian
« Reply #94 on: November 05, 2021, 10:07:16 pm »
Yes I have most of the fittings too.
« Reply #95 on: November 15, 2021, 07:06:26 pm »
Pages: 1 2 3 [4]   Go Up
Page created in 0.032 seconds with 21 queries.
