Hopeitfloats.
You will, in effect have a 12v 4ah battery. You are right in saying the current draw will be equal of each battery. This, of course means the smaller cell will flatten first.
This should work fine until you have discharged the smaller cell, at which point it may suffer damage.
Pugwash
Your 4 batteries will have been mounted in parallel. In which case it's best to use the same type and even batch otherwise slight differences in chemistry will mean they discharge through each other.
