Author Topic: Concrete Springer  (Read 16172 times)
toesupwa
  • USA'd ex Brit
Concrete Springer
« on: April 01, 2009, 09:06:18 am »
Toesup Boat Werks News Release.
There has been the wood, the ply, the glass, the perspex, the foam, the steel.. and the aluminum Springer…
Seeing as the TBW is always pushing the innovative limits and tugnology of the Springer class, I was trying to think of an advanced material that was cheap and easy to use and yet strong enough to stand up to the rigors of Springer football. While I was out at Lowes the other day looking at different materials, suddenly in the construction isle, I found what I was looking for.
Ladies and Gentlemen, the TBW is proud to present a world FIRST.. the worlds FIRST and only Reinforced Concrete Springer….
There is a layer of chicken wire within the concrete, adding strength and holding the concrete together, and within the concrete there is some foam to be cut out that will allow for the gear.
There needs to be some filler here and there as the surface is quite rough… or I might just leave it ‘as is’… the ‘rough and ready’ look…
Tonight’s floatation tests actually look quite promising…
Re: Concrete Springer
« Reply #1 on: April 01, 2009, 09:10:43 am »
I look forward to seeing the trimming and ballasting tests.  :o :}
A springer ramming game could be fun.
catengineman
« Reply #2 on: April 01, 2009, 09:33:36 am »
Question.....
did you "vibrate the air out of the mix when you poured the mould".
I believe that concrete is porous, so a sealant is needed
R                      (I could be wrong)
Arrow5
« Reply #3 on: April 01, 2009, 09:54:27 am »
I foresee a less than perfect "Umi launch" with that one.....being an expert on the subject myself :embarrassed: :embarrassed: :embarrassed:
..well can you land on this?
« Reply #4 on: April 01, 2009, 10:46:44 am »
Will it sail like a "Brick"     ok2
boatmadman
« Reply #5 on: April 01, 2009, 10:47:10 am »
Toes,
I hope you have read the instructions on the inside of the hull? Building codes must be adhered to, and avoid heat as its combustible?
barryfoote
« Reply #6 on: April 01, 2009, 12:04:23 pm »
Just a fancy shaped lump of concrete. It will sink!!!! O0 O0 O0
« Reply #7 on: April 01, 2009, 12:31:47 pm »
They do build boats out of concrete. But the walls are relatively much thiner.
dreadnought72
« Reply #8 on: April 01, 2009, 01:01:56 pm »
I'm looking at the date with a very inquisitive eye.
The long Build
« Reply #9 on: April 01, 2009, 01:05:29 pm »
There is a concrete barge at E'Port Museam , thats still floating I believe..
You are going to video the launch I hope.
craftysod
« Reply #10 on: April 01, 2009, 02:04:17 pm »
Never mind Toes,the men in white coats and your medication will be there soon  {-)
Whatever next ?
Mark
toesupwa
  • USA'd ex Brit
« Reply #11 on: April 01, 2009, 03:18:19 pm »
There was 8" of water in the tub at the time of the picture...   >:-o
Arrow5
« Reply #12 on: April 01, 2009, 04:09:01 pm »
Andy...sharp as a button ;D   Wonder if anybody else noticed.
catengineman
« Reply #13 on: April 01, 2009, 04:36:22 pm »
As it has gone 12:00 has the April fools gag ended yet?
R
amdaylight
« Reply #14 on: April 01, 2009, 04:52:17 pm »
Toes,
Please see Mrs. Toes she has your medicine and knows how and where to take you so you can have a long and safe life.
Next question, how many glasses of the Scottish amber liquid have you had be for thinking this one up? And you need to share some of that liquid!
Now I have noticed a couple of problems, first you should have installed the stuffing box and the rudder tube before you cast the hull. How are you going to secure the deck to the hull? When are we going to see it in the water not just floating in the tub, because in the tub you could have a block of foam under it to make it look like it is floating. I don't want you to be cheating here. <*< >>:-(
Andre
across the river in Portland Oregon
nhp651
« Reply #15 on: April 01, 2009, 09:18:05 pm »
that's it, you've solved the problem of our deep recession and the crisis in the construction industry all in one easy go.
get them diversify into building concrete springer hulls.
brilliant of you, toes. lol :} :} %% %% :-))
toesupwa
  • USA'd ex Brit
« Reply #16 on: April 02, 2009, 03:40:09 pm »
OK.. I'll come clean...  :embarrassed:
Yes, It was an April Fools gag.. The Concrete Springer is virtually solid concrete, there is no reinforcement in it, that was just for the picture.. and it weighs in excess of 30lb.. so no, it wont float.
The pic of it in the tub... it was ballanced on a glass that doesnt show up in the water / picture.
dreadnought72
« Reply #17 on: April 02, 2009, 04:54:12 pm »
Good one!  :-))
It was the size of the foam relative to the s**tload of concrete that made me smell a rat. But (thinner) concrete's maybe not a bad idea for large tug-towing hulls. Cheap enough.
Andy. Do I win anything?  %%
craftysod
« Reply #18 on: April 02, 2009, 08:15:33 pm »
Nice one,was going to send this chap to help you  {-)
Mark
KitS
« Reply #19 on: April 03, 2009, 10:59:39 am »
At some level it ought to work.
Back in the 60s Windboats in Norfolk built a series of river cruisers using a version of concrete they called Seacrete. There was one of them on the quay at Burgh Castle Marina a few years ago. The guy who was cleaning it up was amazed I knew what it was, it seems there are very few of them left, which raises the question 'How the devil do you scrap a concete boat?'
Kit
« Reply #20 on: April 03, 2009, 11:06:58 am »
Many full size yachts have been built with ferroconcrete. It was quite popular at one time as a way of getting a cheap and easily repairable boat. however the non standard nature of the construction makes them hard to insure.
Dreadstar
« Reply #21 on: August 25, 2009, 03:38:54 pm »
The little Clyde ferry that used to run between Largs and Millport,the 'Keppel',was a concrete hulled boat.
Prophet
« Reply #22 on: August 08, 2010, 02:00:53 am »
Strangest Subject i have come across however concrete boats are more common then you might think!
commonly known as Ferroboats. These links might get your cogs thinking for a new project
http://www.ferrocement.org/
http://www.concreteboat.co.uk/WebPages/Links.htm
http://www.trekearth.com/gallery/North_America/United_States/West/California/Santa_Cruz/photo29778.htm
http://content.asce.org/conferences/nccc2010/history.html
http://www.geograph.org.uk/photo/588155
pugwash
« Reply #23 on: August 08, 2010, 04:53:32 am »
Not so strange - from my window I can see the River Coquet estuary and Amble Harbour
where in the 1920s they built concrete boats and there is a 45ft yacht completed up to deck level
made of ferro-crete (concrete over a wire and chicken wire frame). Apparently it is a good medium
for amateurs to build cheaper larger yachts.  If it is done well you get a good boat but nobody ever
seems to buy second hand ferro boats unless they saw it being built as the surveyers can't do a
a proper survey on the hull like they can with GRP or wood
I didn't beleive it either before I moved here.
geoff
« Reply #24 on: August 08, 2010, 06:04:57 am »
In OZ....the Government produced dozens of [ferro cement] DUMB lighters then of gave them a CAL pennant reference....I can only assume CAL stands for Commonwealth Ammunitaion Lighter, many are still in service today after 60 years service
The attachment depicts CAL 501 & from the mooring appears to be westward up river from Cockatoo Island...........you can just make out the Sydney Tower in the distant background above the 5 in the pennant number ..................Derek
