Author Topic: Footie know how sought.  (Read 10802 times)
Popeye
  • I see no ships!
« on: April 02, 2009, 06:52:58 pm »
I've been persuaded to build a footie to complement my buddys' (and hopefully to generate some club interest) and have opted for a swingrig setup (carbon fibre mast and booms) as opposed to my Buddys' traditional sloop rig.
Question:-  should the base of the mast (within a tube glued to the keel )be fixed in position to prevent rotation whilst  - hopefully - sailing, or should it be permitted to rotate freely should it so desire?
Thanx in anticipation of any responses.
Confucius he say, 'if all else fails.......reach for the  Red Top-Stop'.
andrewh
Re: Footie know how sought.
« Reply #1 on: April 02, 2009, 07:42:13 pm »
Popeye,
Welcome to the world of footydom :}
There is a Health warning youshould be aware of {-)
Footys are dangerously addictive and you may have a lot of Fun!
In answer to your question:  It all depends!
The footy swing rig expert par excellence is Roger Stollery (indeed the anything swing rig expert)  Roger makes the mast and main/jib holders all rigidly bonded together and the mast rotates in a tube fixed to the boat.
He may have a bearing fitted to the bottom of the tube - perhaps a ball on which the mast rests - but as long as it rotates fairly freely all willl be well.
For one meeting I fitted a swing rig to my Razor (its second outing).  I made the mast fixed and allowed the "booms" to pivot around it - this seemed to work quite well too (but I'm not a roger S!)
What boat are you making?  Have you discovered this resource?
http://www.rcsailing.net/forum1/forumdisplay.php?f=61
Where there is a lot of discusswion of rigs, swing rigs and indeed "the whichness of the what"
Happy to answer any questions - or point you to an expert
andrew
AndyT
« Reply #2 on: April 10, 2009, 01:23:57 pm »
Andrew, Roger has now moved away to a fixed mast with a wire gooseneck that rotates round the mast and is prevented rising up the mast by a piece of Teflon
The wire is then slotted into both booms
Rgds
AndyT
« Reply #3 on: April 10, 2009, 02:40:47 pm »
What we need on here is a Footie build log.... who's building one?
AndyT
« Reply #4 on: April 11, 2009, 10:47:29 pm »
Now thats not a bad idea as it happens
Rgds
AndyT
AndyT
« Reply #5 on: June 01, 2009, 10:43:00 am »
Martin, I am about to start a Footy build is there any format or place that i should place it within MBM?
Rgds
AndyT
« Reply #6 on: June 01, 2009, 10:48:23 am »
Here is fine!
Any format that suits you ... but the more pictures the better... for me anyway!   :-))
Atlantis Steve
« Reply #7 on: June 01, 2009, 10:49:00 am »
I'm currently designing a new footy complete kit. Still having teething
Troubles but antisipate finish by end of july. Kit will be availible for sale and comes with
All parts except radio gear as soon as I finish designs I will post on website which
Is still under construction. I'll post link asap. SteveG
AndyT
« Reply #8 on: June 01, 2009, 10:54:49 am »
Thanks Martin I will start it today then in a new thread
Rgds
AndyT
kiwi
« Reply #9 on: June 01, 2009, 11:31:16 pm »
Hi Martin,
I've been building some DIFFERENT footy's and could do a build on the next one.
They are in this wiki
http://windling-footys.wikispaces.com/
and if you follow the link on page two (click on the plan photo) this will take you to my web-site for plans.
If anyone would be interested.
Also hope soon to have some little hull laser-cut kits available. (and sails, rigging and fittings kit as well)
Will also be building some other wooden boat footy's soon, such as a dhow, junk, and a few others.
These are all footys for fun sailing, even though they are designed to comply with the 'footy rules'
cheers
kiwi
Popeye
  • I see no ships!
« Reply #10 on: June 02, 2009, 04:52:11 pm »
I attach a few shots of my first Footy and hope that they may be of help to anyone who is contemplating building one
The model is built from Martin Schillers' free plan 'Papaya III and was chosen 'coz it was the only plan I could find with a swing-rig.
Weight is 450 grammes ready to sail.
It's hull is 0.7mm ply, with a 4mm carbon fibre tube mast and 3mm c/f tube swing rig booms.
John C
« Reply #11 on: June 02, 2009, 07:41:38 pm »
Photo's?
John C
Popeye
  • I see no ships!
« Reply #12 on: June 02, 2009, 10:03:40 pm »
Photo's?
John C
Oops, I messed up good and proper. I don't think I'll ever get used to this new fangled technology.
Hopefully , a few shots of my first Footy are now attached,
PS Sincere thanks are extended to Andrew Halstead (AndrewH) and Roger Stollery for their help and infinite patience in responding to my numerous 'how's it done' questions relating to Footy builds.
Popeye
  • I see no ships!
« Reply #13 on: June 02, 2009, 10:06:47 pm »
And a few more.
John C
« Reply #14 on: June 03, 2009, 09:11:04 am »
Nice
I have one of these on my list of projects, but as I'm a free sailer it'll probably be more trad looking when I get around to it.
« Reply #15 on: June 08, 2009, 11:29:48 am »
I would eventually like to build a Footie, where can I find instructions for building the "swing rig?"
Popeye
  • I see no ships!
« Reply #16 on: June 08, 2009, 12:02:56 pm »
Hi Martin,
I presume you're referring to the swing rig booms and mast fitting and not how to build a 'Footy'?
There are a number of free plans, plus oodles of general info  available from footy.rcsailing.net though nought - with one exception to my knowledge - in respect of construction of either the rig or hull.
Email me via Mayhem  'n I'll  pass on valuable tips etc. given to me by both Roger Stollery ( UK model yacht designer ) and  another Mayhemer (AndrewH)- it'll be quicker and more comprehensible than trying to put it all on paper
I await your response,
AndyT
« Reply #17 on: June 08, 2009, 12:08:38 pm »
Popeye and Martin i can help here i have an excellent document
I will start it as another thread and add the sections as PDF's
While writing was the build log on the footy ok?
Enough photos too many / not enough words?
Could you also change the starting title for me so it does not say page 1  Thanks
Rgds
AndyT
« Reply #18 on: June 08, 2009, 12:32:39 pm »
1. While writing was the build log on the footy ok?
2. Enough photos too many / not enough words?
3. Could you also change the starting title for me so it does not say page 1  Thanks
1. OK but smaller step by step stages is (are?) my personal preference... I always have problems with simple instructions.  :embarrassed:
2. As above. Photo instruction, photo, instruction.... but that's just me!
3. Done.  :-))
AndyT
« Reply #19 on: June 08, 2009, 01:04:52 pm »
Martin see what you think to the German swing rig, I know it was for a different Class but the principles are the same and i felt that seeing it on a larger scale helped anyway
Thank you for doing the thread title change but i should have been more specific as i have some other more simple builds i would like to share - Could i ask that you change it to "Footy Pirate Bottle Build" so as to be distinguishable from the others
Thanks in anticipation
Rgds
AndyT
Page created in 0.032 seconds with 21 queries.
