Author Topic: JJC Old Smokey - Converted for twin transom exhausts (Lifeboat)  (Read 2973 times)
johno 52-11
  • Model lifeboats built to perform
    • lifeboat Models
« on: October 04, 2006, 03:11:46 pm »
Here are some links to video clips of the JJC Old Smokey converted to work with transom exhausts on a model of a Severn Class lifeboat.
http://www.lifeboatmodels.co.uk/smoke1.htm
http://www.lifeboatmodels.co.uk/smoke2.htm
http://www.lifeboatmodels.co.uk/smoke3.htm
Voyager
Re: JJC Old Smokey - Converted for twin transom exhausts (Lifeboat)
« Reply #1 on: October 04, 2006, 05:27:35 pm »
Lookin rather good! ;)
flag-d
« Reply #2 on: October 04, 2006, 11:46:06 pm »
Looks very realistic indeed.  The sound is good too: also JJC?  Adding sound to a model really does make a big difference to the realism, I think and at long last, thanks to JJC, there are off the shelf sound units which actually sound like the real thing!  The exhaust smoke is excellent:  I'm tempted by a Severn already and this is making it worse!!!
cbr900
  • Mayhem is the Only Forum!
    • Roys Hompage
« Reply #3 on: October 05, 2006, 07:17:47 am »
It certainly looks and sounds great,
I wonder how long it will be with the way electronics are going before you program what you want you boat
to do on shore, put it in the water press start and it takes it self out does what it is supposed to do and returns to where it left....
Roy
« Reply #4 on: October 05, 2006, 08:44:11 am »
  Away with the fairies again Roy      ::) ::)
  Richard 8)
cbr900
    • Roys Hompage
« Reply #5 on: October 05, 2006, 08:54:18 am »
DICKY<
Mate it is not as far away as you think....
Roy
« Reply #6 on: October 05, 2006, 09:02:17 am »
Looks good.
chromedome
« Reply #7 on: October 05, 2006, 08:43:55 pm »
I cant view these...what plug-in do I need  !!!?
   chromedome
cbr900
    • Roys Hompage
« Reply #8 on: October 06, 2006, 12:44:49 am »
Power point on the wall helps.... ;D ;D ;D
Roy
« Reply #9 on: October 06, 2006, 08:13:49 am »
Poer point on the wall helps.... ;D ;D ;D
Roy
OK Roy , I give up, whats a poer point? I know what a wall is.
Richard    ??? ???
barriew
« Reply #10 on: October 06, 2006, 08:45:26 am »
Tasmanian for POWER i guess!!
Barrie
andywright
    • Windpowersails
« Reply #11 on: October 27, 2006, 05:13:28 pm »
Any chance of a description on how you did it, I know its a jjc unit, but what size piping did you use etc
Navigational Aids vessel Master. Old Conway 70-72
johno 52-11
    • lifeboat Models
« Reply #12 on: October 27, 2006, 05:30:42 pm »
Hi Andy
all the pipe work is overflow pipe the only modified bit is that 2 135 bends where modified and stuck together to make a y connector and there is a small bit of flexable rubber to enable the smoke unit to be easily removed. the exhaust flaps are counter balanced to make them open more easily and the cooling water is by a small pipe glued into the overflow pipe.
andywright
    • Windpowersails
« Reply #13 on: November 02, 2006, 09:56:26 pm »
Thanks John,
I've ordered the unit just waiting for it to come, its going to be fitted to a tug with twin funnels, but when my next tug project is completed it will be twin transom exhaust.
Andy
