Author Topic: zebra receiver  (Read 3884 times)
regiment
zebra receiver
« on: April 05, 2009, 03:34:36 pm »
i have a 3 channel rx tx the receiver is playing up one minute ok next. it stops/ if you move  the plug around in the rx ok, prop side only acting  up will any other make be ok it is a zebra i am using any member got a cheapey to sell hope you can understand my none tech jargon
stallspeed
Re: zebra receiver
« Reply #1 on: April 05, 2009, 04:00:34 pm »
I think it is likely that external connections are more likely to be at fault.
If you swap the esc output to rudder servo or insert a different esc into what you think is a dodgy output you might find that a servo connector plug is faulty.
regiment
Re: zebra receiver
« Reply #2 on: April 05, 2009, 04:18:11 pm »
hi right here we go no 3 channel for lights ok.. prop will not work on no 1 channel  but if i put it in no 2 channel ok but but i have to use the rudder ch for forward and reverse and the prop ch for the rudder then everthing ok
regiment
Re: zebra receiver
« Reply #3 on: April 05, 2009, 04:21:02 pm »
ps everthing works ok on 2 channels  prop on prop rudder on rudder  if you know what i mean
regiment
Re: zebra receiver
« Reply #4 on: April 05, 2009, 04:53:25 pm »
 broken lead on  on plug ( esc  ) dose that mean a new esc  or can a new plug be put on  and by who
Bartapuss
  • Deltic's Rule OK!
Re: zebra receiver
« Reply #5 on: April 05, 2009, 05:14:56 pm »
Any local RC model shop shouild be able to sort that out for you, cheaply. Are you a member of a club by any chance???
Every time I learn something new, it pushes something old out of my brain - I says wot I likes and I likes wot I say!!!
regiment
Re: zebra receiver
« Reply #6 on: April 05, 2009, 05:20:02 pm »
no clubs  here in perranporth no model shops  any sergestions ? question mark is for spelling
Re: zebra receiver
« Reply #7 on: April 05, 2009, 09:16:55 pm »
The metal bits in the plug can  be removed by gently lifting the plastic flap retaining them (sometimes by pressing the metal flap down, depends on make) and GENTLY pulling out, or pushing with a pin from below.  The connection can then be checked, sorted with a soldering iron if required, and reassembled.  It could well be that the receptacle or pin has gained a bit of corrosion or muck or might just need a VERY GENTLE tweak before reassembly to ensure that there is good pressure to make sure of a good electrical contact.
Thats assuming the problem is at the plug end of the wire.  If its anywhere else, much depends on the make of ESC.  Some you can get at the innards to change the lead, others are seal for life.  This means that when it goes wrong, its dead.
Bartapuss
  • Deltic's Rule OK!
Re: zebra receiver
« Reply #8 on: April 05, 2009, 09:50:27 pm »
If you are new to radio control or not confident in your own skills to fault find the problem, my advice is to go to your nearest club, model shop or model boat show. It could be a simple cheap fix is all thats needed, I can't see the point in just ordering up a brand new esc if your having a hard time trying to understand how it works or trying to do it yourself as you could be throwing good money away. Its all too easy for those of us who know it all one here to get a newcomer totally lost and dissenchanted with a load of technical talk, actually getting help face to face for just a few minutes is worth more than a thousand words.
regiment
Re: zebra receiver
« Reply #9 on: April 06, 2009, 05:50:43 pm »
thanks to all who replyed a person down the road runs rc cars took it down to him he cut the old plug off and solderd a new plug on  did not charged me  i now have a new friend
