Finally a proper update again:
Fixed the wheelhouse.
The wheelhouse has smashed quite a lot of times against the shore during a heavy-weather test during which a bad connection between a fuse and it's attachement caused the main engine's to stop working.
In the end the stern had quite a lot of water inside, while the mid- and front compartments were completly dry.
Fixed the breakwater again.
A heavy-weather test caused a steering-lever to break, so i tried to fix it, but that didn't work.
Therefore i ordered some gearwheels to make it able to steer again.
I also ordered a nice kit to make the lights start up like real floodlights, as that saves me delivery-costs.
All needed components for making the floodlights start up like real floodlights.
IC has been mounted.
Soldered the lot with shaking hands.
Just 1 hour of soldering was enough to finish this little project.
A test showed me that it doesn't work properly, as the lights keep burning, rather then flashing a few times before starting to burn continuosly like real floodlights do.
The new gearwheels are way to small.
Plan B is to build a gearbox.
Gearbox under construction.
The Azipods will now turn much faster then before due to the different reduction.
Greetings Josse
