hello all
Just a question - what type of electric motors are you using? Because if its the electric motors which are causing vibration, then, I would bin them. I think there is something seriously wrong with them - as in, something out of balance on the armature or the commy - or a bent shaft. The majority of electric motors I have bought/used run quite silently.
The majority of problems come from either:
a) a cheap, out of line coupling
or
b) a bent prop shaft
You should be able to mount the motor securely in the hull; without the need for any insulation or sound proofing material - as I believe one has already said, all the thrust and tork end up being transferred from the propeller eventually ending up at the motor mount and then being transferred to the hull. Any weak spots between the motor mount and the hull is when you encounter problems where the motor tries to leave the hull.
Im attaching a pic of the three Graupner Speed 600s mounted in the 63ft whaleback running on 8.4 volts - the problem I had, was that I had originally fitted a 'cheapo' red coupling in there and I found it was of line - go for the black couplings.
aye
john
