Hi Peeps,
I've got the smell of balsa in my nostrils and revved up for building. I've made lots of models and the like in the past so my building skills are reasonable but the only boat I've built was 24 years ago whilst wearing short trousers
thanks to one of the guys on here I've now got the plans again to have a go at it again with my boy
- Sea Rider from the Model world TV programe in 1975 - 30inch flat bottom frigate - Thanks Dougal99
Before I loose myself completely in nostalgic waffle
my questions are:
Prop Tube - the one I've got is simply a tube with a shaft/prop - there are no seals on the tube so whats to stop water creeping up the tube or do i just make sure the internal end is above the water line?
Motor linkage - my plan is to use a piece of rubber tubing to give me flexibility on the mounting - is this a sensible thing to do or should i use a some proper linkage?
Rudder - I shall use 2 linkages on it but was going to opt for wire as opposed to solid adjustable ones - am I asking for trouble? I've read some posts on here that strongly advise double solid adjustable but they seemed to be for high spec craft - my boat is really very simple and only for the boy to pootle about with on the duck pond. Little fingers cannot resist turning rudders so I'm concerned it would damage solid ones whereas the wire ones will flex?
Keel - I read somewhere that an experienced modeller had built one of these and put a keel on it for stability - so I'm not sure whether to put one on or not. I understand why I should use one but I want to keep things as simple as possible. My boy is only 7 and a keel would get in the way of his imagination
I think thats it for now...................but I shall be back with more as the weekend progresses - I've got an urge to resurect a half built airboat but I'll save that for another post
