Author Topic: Steam Engine?  (Read 3790 times)
Steam Engine?
« on: April 25, 2009, 01:30:37 pm »
Bradders pick this up at the Wicksteed club on Monday, can anyone tell me anything about it please?
kiwimodeller
Re: Steam Engine?
« Reply #1 on: April 26, 2009, 05:54:52 am »
I have seen something similar which I was told was a "Trojan", 5/8" bore by 5/8" stroke, built from plans first published in Model Engineer in the late 50's. If not it is probably something built at home from one of the many sets of plans published over the years. Never mind what it is, find a boiler, find a boat and get it on the water.
bogstandard
Re: Steam Engine?
« Reply #2 on: April 26, 2009, 07:53:28 am »
Martin,
I have no idea what the name is, but it looks like it will be a slide valve engine.
The inlet is on the side of the steam chest, the same block that the offset displacement lubricator is on. The exhaust is the one on the cylinder block.
Stick a bit of oil first, then air, into the inlet and give it a flick over and it should run, that is if it isn't siezed up.
It will only run in one direction, and no guarantee of self starting, it all depends what position the piston and slide valve is in when it stops. If it anywhere near TDC or BDC on a power stroke, there is not enough momentum to get it to turn over to the next revolution.
It could be modified to run in both directions by putting a slip eccentric on the valve gear, but again, no guaranteed self starting.
I hope this helps.
malcolmbeak
Re: Steam Engine?
« Reply #3 on: April 26, 2009, 08:55:24 am »
I have no idea either, but just for your information, this is what a Trojan looks like. The oil tank is obviously an addition, it feeds oil to the main bearing and through the drilled crankshaft to the other main, the big end and the eccentric. The con rod is machined from solid rather than from the 'orrible bronze casting that was supplied.
Malcolm
