I have a Futaba Skysport 4 TX and, up until now, I have used the charger which was supplied to charge the battery (9.6 v 700 mAh NiCd) via the inbuilt charging socket on the case. I now have a universal charger (NiCd / NiMH) which has the Delta sensing system incorporated which I would like to use instead. Can anyone help or advise with the following questions please:
(A) Will it be OK to use my new charger (MW 168VD from Components.Com) via the
inbuilt socket and will the fact that the lowest output is 500mA be OK because I read recently that the charge rate should be something like 1.5mA max??.
(B) I am 99.9% certain that the middle pin of the case charging socket is + (pos), can anyone please confirm if I'm right or wrong??.
Its good to know that you Guys are out there, you have saved me from many embarrassing situations
Barrie.
