Author Topic: Cannons, Big Guns, Monitors and Loud Bangs....  (Read 13911 times)
Martin [Admin]
« on: May 05, 2009, 09:07:34 pm »
There's a program about the Mary Rose on TV at the moment, (Channel Five 20:00) another
sensational new reason why she sank....
Anyway, I've been doing quite a bit of reading about USS Monitor, other monitors, early Ironclads,
big canons, big guns, effectiveness of such and the blast effectiveness guns gave off. Now I've
never seen a big gun go off ( I would love too.... from a very safe distance!) but with that much
power instantaneously expelled, how on earth do such small "straps" hold the barrel in place on
the carriage time after time when firing?!?!?
steve pickstock
Re: Cannons, Big Guns, Monitors and Loud Bangs....
« Reply #1 on: May 05, 2009, 11:50:32 pm »
Newton.
The straps that hold the trunnions in place are working with gravity and the weight of the gun to hold it in the slots. The blast - and the recoil - are straight back away from the muzzle Normally the gun is free to run so there is no force acting on the straps in an upwards motion as the motion of the gun is the force exerted by the barrell.
There must be better ways of explaining it but it's late and my eyes are going.
Go to a re-enactment and see the guns go off there, Most sakers or six pounders (I know they aren't the same) will give you ample experience of what real heavy metal music is liike. And that is on a reduced charge.
RickF
« Reply #2 on: May 06, 2009, 04:43:52 pm »
Martin,
There are a couple of videos here http://www.cerberus.com.au/videos/callvideo.html - check out "Firing 9inch RML Gun"
Rick
Inkmark
« Reply #3 on: May 06, 2009, 05:24:36 pm »
Martin
Also look at where the trunnions are placed, below the centre line of the barrel.
When they recoil they always kick down at the muzzle end.
As for the Mary Rose programme there are a lot of anomolies.
For instance when a gun fires it runs in until the breaching rope catches it.
To reload it is sponge out, powder and then shot, all using long sticks poking into the barrel.
If the ports were shut the gun crew could not reload the gun unless it was turned round, something they did not do.
All this from the wise lads at Portsmouth dockyard who will tell you that during side to side
engagements guns were prevented from being reloaded by the ship laying alongside.
And black powder does not make that much of a bang.
Saw a demo in America, low powder charge agreed but not as loud as you would expect.
Modern guns are much louder.
I am no expert but the guys at Portsmouth are a wonderful source of information.
Mark
jviewing
« Reply #4 on: May 07, 2009, 04:21:33 pm »
Hi Martin, you will have to try this if you ever go to Malta, at Fort Renella they have one of the Armstrong 100 ton guns and also a field gun which you can fire! highly reccomended and very loud. Attached pictures of son Johnathan firing said gun.
Jeremy
Jimmy James
« Reply #5 on: May 07, 2009, 09:22:50 pm »
If you check the lead of the breaching ropes you will see that they run from the cascabel through a large ring bolt lower centre of the carrage and then to a large ringbolt set into the bulwark .... then the gun is fired and it recoils against the breaching rope the effect is to force the gun down..... the square caps are bolted down to the carriage and help keep the trunnions from jumpring out of their slots
Freebooter
Retired  Ships Officer/ Master.
Experience: 50+ years at sea under Sail, Steam & Motor
Kings Lynn
Martin [Admin]
« Reply #6 on: May 07, 2009, 10:27:18 pm »
I was always under the impression that most cannons fairly leap into the air when fired but from what you guys are saying the weight of the big guns helps absorb the recoil of the.... recoilless guns!
Next question, what where the first cannons not to be made in one solid casting?
RickF
« Reply #7 on: May 07, 2009, 11:20:54 pm »
Actually, I believe the early medieval cannons were made from metal rods bound together with hoops - perhaps that's why they were called barrels? Solid casting came in later.
Rick
steve pickstock
« Reply #8 on: May 08, 2009, 07:29:04 am »
Recoil is a funny thing - well may be not so funny if you get hit by the gun but that's why you stay out of the way!
The recoil - Newton's equal and opposite reaction - drives the gun back against the ropes or across the ground but it only works in one direction - generally, if it doesn't - you've done something wrong.
So on board ship it brings the gun inboard so you can serve the piece, before you run it out to fire it again. On land, it depends on the carriage if it's a wheeled carriage it drives the piece back - and the canny gunner will place stops behind the gun to stop it going too far. But contrary to naval practices you run it up to position before you serve the gun, not after. Obviously with a wheel-less carriage you have to have the stops in place before you fire as running up is a much more difficult process but the stops have to cope with all of the force involved from the recoil as none is lost in the motion of the gun.
The first small guns were cast pots, the technology did not exist to cast bigger ones so they made the barrels by placing iron strips around a former and then shrinking bands around them to hold them in place, and then sometimes they repeated the process. It wasn't an ideal method as the barrels of these stave built guns weren't of an even strength and were quite liable to blow up.
Incidentally marine archeaeologist Mensun Bound has discovered that the Elizabethan navy were using a uniformly cast gun, instead of guns of all different sizes, all of the guns on the ship would be the same weight of shot.
http://www.alderneywreck.com/node/62
That's about 70 or so years before it was thought that was done.
plugger
« Reply #9 on: May 08, 2009, 04:00:21 pm »
The Fremantle Maritime Museum Shipwrecks Gallery has a cannon recovered from a wreck on the Western Australian coast dating from the 1600s - from memory it was a Dutch East India vessel. This gun was an experiment in different casting. It was made from 30 or so iron bands wrapped around a copper tube. The lot was sheathed with I think copper (but could be brass - did not take a photo last visit) and the gaps in  between filled with molten lead. A section along the barrel length has been removed - you can clearly see the different metals used.
Plugger
Jimmy James
« Reply #10 on: May 10, 2009, 10:01:16 pm »
Peter the Great I believe used guns bound in leather with a metal bore in his army this made them very light and easy to transport BUT they only had a limited life. The Chinese used guns made of bamboo wrapped tightly in raw hide the shot was a steel tipped bamboo arrow which is said to have had a range of up to .75 of a mile
Freebooter
Kings Lynn
Martin [Admin]
« Reply #11 on: May 11, 2009, 01:52:23 am »
So when were the first cast cannons?
 And what was the next stage in cannon development after casting?
steve pickstock
« Reply #12 on: May 11, 2009, 07:28:43 am »
As for the earliest cannons - it depends who you ask - the chinese probably had the earliest sometime in between the 5th and 10th centuries AD, simple bronze pots or arrow firing bamboo devices. In the west hand cannon appeared around the 1260s, probably brought from the east by the Mongols. Artillery was first used in Spain in the 13th century before becoming more widely used in the 14th.
By the 15th the designs had been ironed out to pretty much what you would call a 'cannon'
http://www.st-max.org/images/woodcuts/unmodified/Landsknecht_Artillery-2.jpg
http://www.st-max.org/images/woodcuts/unmodified/Landsknecht_Artillery-1.jpg
Ship board guns were getting there too.
Breech loading - after a fashion - was an early development alongside the stave built guns. You often see early artillerists carrying a small 'mug' shaped device which is the charge and/or ball, and sat at the back of the barrel, wedged in tight.
But the biggest development - in my opinion - was rifling. Things like the screw under the barrel for elevation and the Gribeauval system of carriages that Napoleon brought in, or the various types of guns like long guns, carronandes or the like were just evolutions of the same thing - but rifled guns allowed more consistent accuracy and because of the complications of loading virtially forced the designers to work out a sensible breech loading design. From there cartridge based ammunition was a logical next step.
« Reply #13 on: May 11, 2009, 10:21:03 am »
Hi all....Steve....please consider & take another step backwards in that rifling of barrel created a projectile that "spun" during its intended trajectory toward the intended target...........
The simplest way to consider this is a comparison to the gyroscope...........which in it self is a spinning device passing through space.....Derek
steve pickstock
« Reply #14 on: May 11, 2009, 11:29:54 am »
Derek - I did consider that - hence my comment about consistent accuracy.
However important as that was - and it was very important, it was not as crucial in the next step as what rifling MADE people do next.
Napoleonic smoothbore gunnery was pretty good. The best gunners were accurate within the limits of windage and powder. Rifling - as it had been developed for handheld firearms was a logical development of this, although there were earlier rifled guns, nothing of any major size it had been done before.
However as industry developed in the 19thC and screw/thread technology developed it became easier to rifle a cannon barrel, however at the same time it became easier to create an interrupted screw breech block. Introducing the charge and projectile at the rear allowed for the develope of the artillery shell as we know it. And that is the step forwards - if you look at a modern gun as fitted on an RN warship in 2009 it is still the same basic gun as was fitted in 1914 - just a few more whistles and bells.
What I'm trying to explain - badly - is that rifling as a step in the development of artillery was important in terms of accuracy, what it led onto was more important.
The next stage in artillery will need to be a move away from propellant/shell/tube technology to something like electromagnetic propulsion rail guns or something like that.
« Reply #15 on: May 11, 2009, 12:24:39 pm »
Hi all....Steve ...
a) we have systems & satellite's which confirm where our respective enemy is
b) we have systems & satellite's which confirm where our next threat is from.....& in how many minutes time
c) we have systems in place to counter any aggression  - Let us pray & naturally this woud include ~~~ as required ....an  ICBM multiple launch from any designated site
We could ask ourselves ....in hindsight....? are we any different than our waring navies of 200 years ago?............apart from a little time?.........Derek
Inkmark
« Reply #16 on: May 11, 2009, 12:30:27 pm »
Hi Guys
Gun development history is a bit hazy.
As for the first cast guns do we consider relibility in this? Lots of the first cast guns exploded so the technique was abandoned for a while.
So do we consider the first or the first reliable?
Mary Rose has breach loading guns with the pot cannister that Steve describes, held in place with wooden wedges.
This must have been unreliable because we see guns going to muzzle loaders after that.
With rifling, Warrior had 'rifled' Armstrong guns but these were unreliable and abandoned, we sold them to the Confederates.
There is still an Armstrong on the battlefield at Manasas.
Then there is the ammunition. A bag of powder and a big iron ball is a lot more reliable than a shell made in a factory and stored for a while.
I have seen figures that suggest that up to 40% of WW1 ammunition did not behave as expected.
So there a lot of modifiers here, just like today, something that works well in trial may not suit the rough and tumble of battle.
The gun or any other device has to be easy to use, reliable and not fall apart when used hard.
Interesting thread.
Mark
Jimmy James
« Reply #17 on: May 11, 2009, 10:25:51 pm »
If I remamber correctly one of the largest caliber guns ever built is still fired on certain holidays ... It is one of the forts in Malta and has over a 20" bore
 One has to remember the range of the old smooth bore cannon gave the world the international boundaries at sea (3 N/Miles) untell someone discovered oil under the sea now its between 200 & 2000 N/M depending where you are.    Mr Shrapnel (He was a Brown Job can't remember his rank) invented the shell that is named after him & the French invented the breach block that is used almost universally on large cal. guns with the interupted thread though some of the smaller & mid cal.quick firring guns use a sliding breach block
Freebooter :-)) {:-{
Kings Lynn
Wasyl
« Reply #18 on: May 27, 2009, 11:10:08 am »
I have a working model of a ships cannon,its made of cast iron,and is approx 400mm long and has a bore size of 18mm,it is on an oak limber,and weighs approx 12kg,and i have test fired it using synthetic blackpowder,it works,the 18mm soft lead ball, ended up as a flat lump approx 75mm dia,this was after it hit a steal plate
Wullie
Martin [Admin]
« Reply #19 on: May 27, 2009, 12:23:23 pm »
I bet you don't get many burglaries around your way Wullie!!!!   :o
Wasyl
« Reply #20 on: May 27, 2009, 12:57:16 pm »
 {-)Being in the middle of nowhere,a man needs protection,mind you the next time i fire it,i,ll have to make sure i secure the limber to something solid,because last time,the cannon went backwards as fast as the ball of lead went foward,and the cat s**t itself so did i, i did,nt think the bang would be so loud,
its quite hilarious,really,we tried to make our own black powder,i.e.sulphur,charcoal,and a magic ingredient
 %%i hate the smell of rotten eggs,all we got was a big puff of acrid smoke,and that smell,
Wullie
tobyker
« Reply #21 on: May 28, 2009, 12:20:12 am »
I suspect jviewing's lad would have been squashed by the field gun if it had been shotted. Have y'all seen the film of those WW1 howitzers climbing up their recoil ramps?
Wasyl
« Reply #22 on: May 29, 2009, 11:08:34 pm »
The guy who made my cannon, he also has made a a working model of one of those WW1 field guns,its a 12th scale model of a 4.5in gun and fires a 9mm blank??but can also fire a round,it too recoils well,
Wullie
farrow
« Reply #23 on: May 29, 2009, 11:36:01 pm »
Hi Martin, you where asking about the development of cast guns. In England King Henry VIII was the father of the development of efficient iron caste smooth bore muzzle loaders. He spent a vast amount of money/time and interest in the subject, it is believed it his development which brought about the demi culven cannon which proved so effective against the Spanish Armada. The later guns in the Napoleonic wars where a simple development of the Tudor cannon, the main development being the British technick to caste the gun in a whole then bore out the barrel. This gave a good reliable gun which did not explode when it got hot with heavy use, the French caste theirs with the hollow bore in one go, which made them liable to explode under heavy use, which explains why the English ships got more rounds off to the French who where known to abandon hot guns in fear. Also with the mention of land guns leaping up, I thought I should mention to you that from late Napoleonic times, some field pieces and later all had spades fitted into the bottom at the rear of the gun carriage to reduce the distance of recoil by digging into the ground, which encourage the gun to leap up at the front.
Martin [Admin]
« Reply #24 on: May 29, 2009, 11:47:36 pm »
"caste the gun in a whole then bore out the barrel. This gave a good reliable gun which did not explode when it got hot with heavy use"
In layman's terms...... why?
