Author Topic: Prop Size  (Read 4673 times)
andyn
Prop Size
« on: June 01, 2009, 10:10:47 pm »
What sized plastic prop for a 540 motor?
Will be 3 bladed one of these, or I'm very tempted to get a 5 blade for the hell of it, because it will look nice...
http://www.cornwallmodelboats.co.uk/acatalog/plasticm4.html
Also, does anyone make a very small water pump?
Re: Prop Size
« Reply #1 on: June 01, 2009, 10:23:47 pm »
Whats the tug
Stav
andyn
Re: Prop Size
« Reply #2 on: June 01, 2009, 10:26:03 pm »
http://www.wearboats.com/apps/webstore/products/show/586420
Won't be tugging anything, just looking nice ;)
Tuned 540 motor on 6 cells.
Re: Prop Size
« Reply #3 on: June 01, 2009, 10:31:00 pm »
Taht size should be OK personally I would go for the Brass prop
Stav
andyn
Re: Prop Size
« Reply #4 on: June 01, 2009, 10:32:26 pm »
So would I, if I had any money, spent it on the hull and propshaft...
Which size should be ok? Will the pretty 40mm 5 blader be ok?
andrewh
Re: Prop Size
« Reply #5 on: June 02, 2009, 05:08:54 pm »
Deep inside you know that it depends on the load - ie the pitch of the prop
I'm running a s600 (550) with 40mm 2-blader  on 8 cells and the motor is not in the slightest bothered - I would say give her a try but it might prefer a low gear ratio like an olympus or 2:1 if its a tuned buggy motor
andrew
andyn
Re: Prop Size
« Reply #6 on: June 02, 2009, 05:50:39 pm »
I've ordered both the 40mm five blader and a 40mm 3 blader, and we'll see how we get on :-))
Haven't even got the hull yet, it went in the post today apparently. I have all of the kit I need lined up for it on my bench.
craftysod
Re: Prop Size
« Reply #7 on: June 02, 2009, 10:28:27 pm »
Andy going for a tug,what next
Dont tell me its going to be ic powered  {-)
andyn
Re: Prop Size
« Reply #8 on: June 02, 2009, 10:56:52 pm »
SHHHHHH ;)
This year's springer of mine may be getting a Sikky engine, Hush Hush...
craftysod
Re: Prop Size
« Reply #9 on: June 02, 2009, 11:09:36 pm »
On a serious note now,
If anyone else reading this post, about brass props.
If you get them of ebay,unless its a reputable dealer,dont buy.
I ordered 2 and they were broken when i received them,they were soldered and not cast.
Just to save you money
Mark
andygh
Re: Prop Size
« Reply #10 on: June 03, 2009, 10:05:34 pm »
I've used many silver soldered props, none have broken  :o
More Coffee
Re: Prop Size
« Reply #11 on: July 12, 2009, 08:05:17 pm »
On Bender ..my little tug ..i used a brass 4_blade Rivabo 45mm
550 can motor ..dual 7.2 volt Nimh packs in paralell
andyn
Re: Prop Size
« Reply #12 on: July 12, 2009, 10:23:40 pm »
I've ended up with a VERY hot 540 motor (just because I had it) and a 5 blade 40mm. It reaches scale speed with a couple of clicks on the trim lever, aquaplanes at half throttle and can pull me in our very heavy rescue boat. All from a 24" tug...
Page created in 0.206 seconds with 22 queries.
