Author Topic: esc  (Read 1219 times)
regiment
esc
« on: June 03, 2009, 03:20:12 PM »
have just been given a 25a sea hunter  esc is it possible to test it in any way to see if it works
andrewh
Re: esc
« Reply #1 on: June 03, 2009, 04:48:47 PM »
I don't know the beast but yes,
  • plug it up to a load - motor or car headlamp bulb,
    servo tester (ideal)  or receiver
    battery - suggest you start low power and volts  - perhaps 6 cell nicd pack/6V lead or whatever you have
Try it
A little research seems to suggest it is the ESC supplied with Tomcats (I assume that's not the F14 :}) so it should be pretty bulletproof.  I think the Tomcat has a warm 550 motor (perhaps 15 Amps) and I have seen 6 to 10 cell mentioned  (effectively 6 to 12 volts)
You will now be inundated by the mayhemmers who know the sea hunter like the back of their hands :}
andrew
Electronic things usually have a "digital" functionality - they generally work or they don't
