Author Topic: pusher tugs or tow boat  (Read 12593 times)
portside II
  • tugs at rest
Re: pusher tugs or tow boat
« Reply #25 on: June 22, 2009, 09:59:13 pm »
Hi destroyer , tried the link but it was broken , but i know of the site so here is the link again.
http://oldriverbillzumwalt.members.ktis.net/wheels_&_korts.htm
daz
tubby tomo
« Reply #26 on: June 24, 2009, 12:28:23 pm »
hi thanks for info when 3 props are used you can use 2RH or2LH as manly used for more power when needed
bulerthebishop
« Reply #27 on: June 24, 2009, 01:29:42 pm »
{:-{hi I'm going to bring up a subject that's been on here before about three props what prop goes in the middle RH-LH
This pic clarifies the direction of centre prop, at least on this tug, it is L/H same as port prop, but I am not sure it makes any difference!
tubby tomo
« Reply #28 on: June 25, 2009, 01:27:40 pm »
hi Brian what web site did you get pic from
bulerthebishop
« Reply #29 on: June 25, 2009, 06:27:02 pm »
www.pousseurs.fr/    How's your French?  Mainly French Pushers, but German and Dutch too.  A good pic of Medart out of the water, gives good view of hull shape, click on links at left side .
portside II
  • tugs at rest
« Reply #30 on: June 26, 2009, 12:38:56 am »
That's interesting Brian , on the photo of the pusher DECIDE out of the water shown from the stern , it clearly shows the twin kort's and the rudders , but it may be my eyes the korts look like they are steerable as well .
I have not seen this combination before , is it common on pusher tugs.
http://www.pousseurs.fr/cft_rhone/cft_decide.html
its the bottom pic.
daz
bulerthebishop
« Reply #31 on: June 26, 2009, 03:58:31 pm »
its the bottom pic.
daz
I don't think the Korts are steerable, the rudder shaft appears to go up through the hull, this would not allow the Kort to swivel.  The bottom forward edge of the rudder appears to be attached to the bottom of the Kort just for support.
towboatjoe
  • Rollin' on the River
    • Towboat Joe
« Reply #32 on: June 26, 2009, 09:45:42 pm »
It looks to me like straight shafts. I think what you see is the shaft supports going up to the hull. Here's what a typical tunnel stern with korts look like in the U.S.
portside II
  • tugs at rest
« Reply #33 on: June 26, 2009, 09:54:55 pm »
Yep your right   :-)) the port kort looks like it is on an angle .
It's either my eyes or an optical illusion  %% .
daz
Page created in 0.159 seconds with 21 queries.
