Author Topic: WTC size  (Read 13733 times)
das boot
WTC size
« on: June 18, 2009, 04:42:26 pm »
This should be big enough...what you reckon?
sheerline
Re: WTC size
« Reply #1 on: June 18, 2009, 07:26:53 pm »
Rob, that look s a bit big mate, it will take a lot of lead to kill the buoyancy and you will have make room for it. I looks like you have no room for batteries either.
das boot
Re: WTC size
« Reply #2 on: June 18, 2009, 08:49:55 pm »
Fear not chap...that was just as it arrived today. I'll only need about half of it roughly...main power battery up f'ward  in the wet area, ballast tank dead centre.
Rich(not Rob.... <:()
amdaylight
Re: WTC size
« Reply #3 on: June 18, 2009, 10:21:51 pm »
Rich,
Did you get that from Ian, it is ROUND in one dimension . Did you give up on the the other sub (The Titanic ) you were thinking about building ?
Andre ;D
over yonder in Portland Oregon
sheerline
Re: WTC size
« Reply #4 on: June 19, 2009, 12:08:01 am »
My apologies Rich, don't know where the devil I got Rob from!   :embarrassed:  It's me age mate!  {:-{
Subculture
    • Dive-in to Model submarines
Re: WTC size
« Reply #5 on: June 19, 2009, 10:33:38 am »
Yes that would be a heavy boat, about 40 pounds by my calculations to displace that cylinder.
das boot
Re: WTC size
« Reply #6 on: June 19, 2009, 03:56:36 pm »
Isn't getting old a terrible fate to befall anyone, Sid?   ;D
Oh thanks Andy...that's put me right off building the thing! No, I reckon about half of that tube will be ample...so that's down to 20 pounds then, is it?   :D
Thanks guys,
Bert
das boot
Re: WTC size
« Reply #7 on: June 19, 2009, 06:56:25 pm »
Rich,
Andre ;D
Andre..no, not given up at all on Titanic. The Victor is to be a long term project, Titanic is half finished, I'm waiting on the shafts and props.
Chris...you SURE I can't persuade you to make a 1/60th scale radar pod?
Turbulent
Re: WTC size
« Reply #8 on: June 19, 2009, 08:36:56 pm »
Dim's mate, when you get 5. cheers :-))
das boot
Re: WTC size
« Reply #9 on: June 19, 2009, 08:43:33 pm »
Turbulent
Re: WTC size
« Reply #10 on: June 19, 2009, 08:54:25 pm »
internal Dimensions (Dims) of the tube for your caps :-))
das boot
Re: WTC size
« Reply #11 on: June 19, 2009, 09:01:41 pm »
I knew that..... :D
Hold up mate....2 ticks.
External Diameter: 150mm
Internal Diameter: 144mm
Wall Thickness: 3mm
Cheers mate,
amdaylight
Re: WTC size
« Reply #12 on: June 19, 2009, 11:28:12 pm »
Turbulent,
You have been spending too much time with AutoCad, I have a hard time not telling some one that I am sending them a "dwg" and typing "SP" and hitting "enter" and being upset when I don't get the spell checker, or typing "PP" and not getting it to print in Word or any other program other that AutoCad.  O0
Andre
das boot
Re: WTC size
« Reply #13 on: June 20, 2009, 08:54:00 am »
I wish you lot would talk good old Queen's English like wot I does....
Subculture
Re: WTC size
« Reply #14 on: June 20, 2009, 10:37:06 am »
Yep!
sunworksco
Re: WTC size
« Reply #15 on: July 07, 2009, 07:09:23 pm »
I'm using a 152mm inside diameter WTC in my 1/32 scale Type IX-C submarine with 2- Engel 750ml diving tanks.Still working out the overall length of the WTC.I'm thinking around 914.4 mm long WTC in the 2400.3mm long hull with a 215.9mm width.I work with shedule 40 - 6" (152.4mm) www.harvel.com clear pvc pipe.My bulkheads will be made out of bearing bronze and will support the shafts and control rods.  8)
sheerline
Re: WTC size
« Reply #16 on: July 07, 2009, 08:46:34 pm »
Sounds about right, not sure about those bearing bronze bulkheads though, sounds like a bit of overkill!
sunworksco
Re: WTC size
« Reply #17 on: July 08, 2009, 07:18:18 am »
I will post an image when the parts are fabricated.
I work with bronze,brass,aluminum and copper in my occupation and sil-floss solder metals ,so I am very comfotable with this type of fabrication.
sheerline
Re: WTC size
« Reply #18 on: July 08, 2009, 07:52:46 am »
I look forward to seeing the pics, it certainly sounds like you have thought it through and given your trade, I imagine this will be some form of engineering excellence you are about to create. Good luck with it all.
sunworksco
Re: WTC size
« Reply #19 on: July 19, 2009, 10:12:18 pm »
I am having second thoughts about the wtc size.The hull width can not support that much diameter so am going to use a 114.30mm O.D. X 101.55 I.D. wtc tube.I can then use a Norbert Bruggen bayonet ring set for the wtc caps.
Subculture
Re: WTC size
« Reply #20 on: July 19, 2009, 11:22:18 pm »
What is wrong with a set turned from plastic (PVC, acrylic, acetal, polycarbonate etc.).
Cheap and effective.
The bayonet rings are a really expensive way of getting an endcap, and you will still have to cap them off.
sunworksco
Re: WTC size
« Reply #21 on: July 20, 2009, 12:11:15 am »
I'm using bearing bronze plate for the outer bulkheads inset into the bayonet rings.I work in metal machining ,so no big problem for me.The machinable plastic is almost as expensive as the metal material.I would rather solder the shaft and bearing supports onto the bulkheads.The bayonet rings are some of the best sealing techniques out there.
Subculture
Re: WTC size
« Reply #22 on: July 20, 2009, 05:56:53 pm »
Yeah, but how are you going to attach the bronze plates to the aluminium bayonet rings?
All that metal means weight, in a place you don't want it- i.e. quite high up.
It's quite possible to use a sledgehammer to crack a walnut, but nutcrackers will suffice.
sunworksco
Re: WTC size
« Reply #23 on: July 20, 2009, 06:38:25 pm »
The outer bayonet piece will be machined in bearing bronze plate with the bulkhead designed in the open area of the ring making it one-piece.
Subculture
Re: WTC size
« Reply #24 on: July 20, 2009, 08:01:09 pm »
