Author Topic: Gear removal from motor shaft????  (Read 4064 times)
Mark47
« on: July 05, 2009, 02:02:18 pm »
Can anyone tell me how to remove the gear cog off of a motor?
I've just rescued a nice 550 5 pole from my old cordless drill and can't figure out how to get the gear cog off the shaft. I don't see any locking hexes.
Many thanks, :-))
Mark
Re: Gear removal from motor shaft????
« Reply #1 on: July 05, 2009, 04:32:21 pm »
Assuming that the cog is no longer required, I would cut a slot in a piece of steel, or get two pieces, and support the cog across a vice/ couple of lumps of wood, then use a centre punch, or nail as it is sometimes known, to smartly whack the end of the shaft with the small lump hammer.  This should then start its retreat down the inside of the cog.  Repeated blows will chase the shaft out of the cog.  Or buy a proper tool (probably not an option).
Often, the cog will have been a shrink fit, heating it to expand it might not do the motor any good.
Over to proper engineers.
catengineman
« Reply #2 on: July 05, 2009, 04:37:18 pm »
Rather than shock your motor why not grind one side of the cog until it is thin enough to snap then just pull the remaining part off, or use a dremel cutting disc and slice down to the shaft (but not through it) on both sides and the cog will just drop off
R,
portside II
  • tugs at rest
« Reply #4 on: July 05, 2009, 06:26:14 pm »
the last time i removed a cog from the shaft of a motor , i clamped the cog tightly in the vice and with a pair of safety goggles for protection  :-)) i split the cog with a cold chesil and hammer , sorted  :-)) .
daz
I like to build my boats to play with, not to just look pretty,so they dont !
ray123
  • mary marie cygnus gm33
« Reply #6 on: July 05, 2009, 09:58:50 pm »
R,
i did the same  a tryed & tested way :-))  (but i did put some tape over the holes at the end so as not to get any cutting dust inside the motor) regards ray
catengineman
« Reply #7 on: July 05, 2009, 10:36:26 pm »
Do it all the time at work its probably the fastest way to remove old bearings from conveyor roller shafts.
R,
Martin [Admin]
« Reply #8 on: July 06, 2009, 12:46:00 am »
If it's a brass gear, I once clamped it up in a vice and it squashed it right off.
 As Ray says, seal up any holes in the motor to prevent any ingress of any FOD!
Mark47
« Reply #9 on: July 06, 2009, 08:31:26 am »
No it's steel mate.
I tried the dremmel last night, but the but the motor shaft is too short to cut right through on both ends of the gear. I'll need to get a smaller circumference cutting disk to get it off. No real rush to use it. Just wanted to save it for a future ship, so I'll just keep plugging away at it until I get it off or have to throw it in the bin, which ever comes first. {-)
Mark
Martin [Admin]
« Reply #10 on: July 06, 2009, 08:59:41 am »
'Place your bet .... now!'
Mark47
« Reply #11 on: July 06, 2009, 09:22:46 am »
boatmadman
« Reply #12 on: July 06, 2009, 09:47:04 am »
Tape off all the motor holes and file the gear until it exposes the shaft, it should then be easy enough to release from the shaft.
Ian
« Reply #13 on: July 06, 2009, 09:48:56 am »
You could try the old method some of us used to do with the brass gears, apply a soldering iron to the gear. The heat is usually enough to allow it to expand, Hey you may actually be able to re-use the gear. Tight a**e Yorkshire tricks again.
      Regards    Ian.
« Reply #14 on: July 06, 2009, 09:58:00 am »
Mark47.....there are alternate pinion removal methods
1] hold the 550 motor with the 10 mm diameter pinion engaging your standard 6" bench grinder wheel
..so 3.14x152=477.28mm circ of the grinding wheel........3.14x10=31.4mm circ of the pinion
..say 6000 RPM of the grinding wheel would be approx 92000 RPM of the pinion being ground......... <*< ....best not try this approach
2) hold the 550 motor with the 10 mm diameter pinion engaging your standard 6" bench grinder ...however with a lower pinion gear lobe secured with a pair of medical pincers to eliminate the pinion rotating
...grinding the brass pinion gently will break the shrink fit  & release the shaft :-)) ....Derek
Honorary Secretary
bogstandard
« Reply #15 on: July 06, 2009, 07:11:48 pm »
Oh! you naughty person Derek Warner.
Fancy telling someone to grind a brass pinion off on a grindstone, when you should know you never grind anything softer than ferrous on a bonded wheel.
Just wait 'til I tell the teacher. :}
Mark47
« Reply #16 on: July 06, 2009, 08:48:55 pm »
As I said in an earlier post, it is not brass it's steel. It came from a cordless drill. I would not have asked if it was brass, that's easy to get off, but steel that's a whole other problem. O0
Mark
bogstandard
« Reply #17 on: July 07, 2009, 06:53:27 am »
Mark,
I noticed you had said steel, it was just me having a bit of fun with Derek. I wanted to get him huffing and chuffing.
In fact I have removed hundreds of the damned things, both steel and brass.
I use a pair of very strong and specialist electricians side cutters. Just put the cutting edges into the teeth from the end and squeeze, it works every time. The gear just falls in half.
I didn't want to mention it because people would try to use their cutters they bought from the market stall, and they would just end up with a pair of cutters in two separate pieces. But now it is out.
Bogs
Mark47
« Reply #18 on: July 07, 2009, 07:08:21 am »
Mark,
Bogs
Unfortunately, I don't have a set of cutters, may have to invest in some O0
Mark
« Reply #19 on: July 07, 2009, 07:24:25 am »
Mayhemers....what bogstandard does not realise is that 'Australian >>:-( Abrasives'.....have recently developed a new grinding wheel material based on aluminium hydroxide "7"  + silica + graphite [al+{O2...7}+{H7}+Si +C4]...I thought that would have been simple  %% %)
One of the unique qualities is that it does not 'load up' when grinding non ferous metals
Mark47...my apologies...yes when I re-read your posting....clearly 'steel' is the operative word as mentioned...mind you if it were brass I would recommed the newer [al+{O2...7}+{H7}+Si +C4]...wheels .......
Just try & GOOGLE ....[al+{O2...7}+{H7}+Si +C4]...the results would be interesting........Derek  {-) O0
Honorary Secretary
bogstandard
« Reply #20 on: July 07, 2009, 12:05:40 pm »
Hook, line and sinker Derek.
How long did it take you to find that answer.
In fact, you are now one up on me, I have never heard of what you are on about, must investigate that one.
But on the other hand, how many other people on here haven't heard of it as well, and by your recommendation, would just go ahead and grind away on a standard ali oxide wheel.
Just to update the people on here, as some most probably don't have an engineering background.
Any material that is not ferrous or above, should NOT be allowed to touch an ali oxide bonded grinding wheel (normally fitted to the cheapo offhand grinders that are available everywhere), unless it has been specially bonded to allow grinding of softer materials.
The harder the material, normally the softer the wheel to be used. So softer materials must use a much harder wheel.
The soft particles from whatever you are attempting to grind clog up the gaps in the bonded wheel, and force the oxide particles apart. This can lead to catastrophic failure of the wheel, which propel at high velocity, in all directions, pieces of the fractured wheel. If a piece hits you, expect very deep penetration wounds.
I had my woodworking neighbour come around last week to have his screwdriver reshaped. I knew he had a grindstone, and I asked him why he didn't use that.
'Oh I never grind metal on my wheel, I only use it for wood, and besides, it is all clogged up, and you haven't got a spare one knocking about anywhere'.
This was from someone who thinks that metal is any other material harder than aluminium. He never asks for brass or steel, just metal.
After reading him the riot act, not only did I refuse to give him one of my many spare wheels, I refused to do his screwdriver mod as well.
Up until now, he has been exceptionally lucky.
Do you feel lucky, when sharpening your pencil on the grinder?
Bogs
