Whatever happened to the simple procedure of drilling a small hole in the back of the meter,and inserting a thin piece of wire,to stop the wheel,it worked every time,But it was all panic stations when we got an unexpected call from the meter reader,whilst the wire was still in,
Then there was the little transformer from a radio with 2 wires attached that you stuck up where the main currant wires were,again it worked,but this method was not without its hazards,sometimes all you got was a big flash/bang,and wet pants
But the most dangerous method i ever saw,was when i was working as a maintenance man,servicing student flats,we were called to a block one day,Where we were met by cries of "we,ve no electricity"
Some bright spark, had driven a 6in nail with a cable attached right into the main supply,coming into the building,suffice to say,it did,nt work to well,
Wullie
