Author Topic: Use of Futaba Skysport 4 with a hitec receiver?  (Read 6023 times)
gyronuts
« on: July 15, 2009, 04:50:38 pm »
    I have a hitec Zebra 3 40 Mhz FM Tx with a Hitec 5 channel Rx ZR 106SF, the set up provided with the Zebra 3.
 The throttle is set up on the trim on top of the Tx and the diving planes on my sub are on the throttle.
Must be getting old as I am finding it extreeeeeeeeemely difficult to co ordinate the two!!!!
however, I have a Futaba skysport T4YF 40 Mhz Tx for my other boat but when i try it out with the zebra TX crystal fitted, the hitec Rx does not respond..just gitters etc.
 Do i have to dismantle the model to fit another Rx , or buy a hitec 4 or 6 channel TX ( would that be compatible)... or what would you suggest?
thanks. Bill
photo of the sub
Ghost in the shell
Re: Use of Futaba Skysport 4 with a hitec receiver?
« Reply #1 on: July 15, 2009, 05:22:40 pm »
put a Futaba xtal in the tx
simples *!! ;)
Go Nuclear!  you'll love it
gyronuts
« Reply #2 on: July 15, 2009, 05:48:11 pm »
Hadn't thought of that thanks.
 Here is another one for you....if the throttle on the hitec is the slider on the top, and my control of the planes was on the throttle..on the futaba 4 will the throttle be on the right and the planes on the left.
It is a conventional throttle left Tx.
 thanks again. Bill
barriew
« Reply #3 on: July 15, 2009, 06:25:36 pm »
Yes - I think  %% On the 4 channel Tx you will have channels 1 & 2 on 1 stick, and  3 & 4 on the other. On your 3 channel, the slider is channel 3, so should be on the opposite stick to the planes.
Hope his helps!
Barrie
gromarlie
« Reply #4 on: July 15, 2009, 07:34:41 pm »
Fit a futaba crystal in the futaba transmitter and all will be well except the channel assignments are different on the hitec and futaba <*<
Futaba use
channel 1 as primary direction control (aileron)
channel 2 as elevator
channel 3 as throttle
channel 4 secondary direction control (rudder)
I can't remember the hitec assignments but the simplest answer will be to waggle a stick you want to use for a particular function and then plug the relevant servo into the reciever channel that responds  :-))
gyronuts
« Reply #5 on: July 15, 2009, 08:12:48 pm »
thanks. problem is that the receiver is in a waterproof cylinder which is very ,very difficult to get at. Bill
Subculture
    • Dive-in to Model submarines
« Reply #6 on: July 16, 2009, 10:22:42 am »
That's what is known as hard cheese!  %%
gyronuts
« Reply #7 on: July 16, 2009, 01:27:56 pm »
futaba crystal worked a treat. throttle on the left but movement reversed, rudder on the right stick movement reversed and planes in the correct sense on the right stick.. Magic. only need to change two switches ( and the crystal!!) to operate both subs. thanks. Bill
Ghost in the shell
« Reply #8 on: July 16, 2009, 02:31:06 pm »
said it would work :)
simples * ;)
gyronuts
« Reply #9 on: July 16, 2009, 02:41:39 pm »
yup you did. the other sub!!.Bill
Ghost in the shell
« Reply #10 on: July 16, 2009, 04:29:54 pm »
that looks more manacing than the the other sub :)
gyronuts
« Reply #11 on: July 16, 2009, 08:47:57 pm »
the small one is 28" long the U boat is 44" long.
