Hi SS,
Sorry, wasn't trying to start a war or anything, just trying to avoid a potential misconception as regards to safety.
Yes Mike is on the ball with his recommendations, however, I feel he is being just a little over cautious in recommending the 5" boiler.
His 4" boiler is capable (according to his figures) of producing 800 cu ins steam/minute @ 50psi which means the boiler is capable of evaporating just a little under 2 cu ins of water per minute at this pressure.
At 80psi (the max working pressure of the boiler) this same 2 cu ins water will produce 560 cu ins of steam.(Assuming the burner is capable of keeping up with the demand at this pressure)
Since your triple will only require 530 cu in steam/minute @ 600rpm then this should be more than enough for your engine.
Naturally though, should you wish to run faster than this (or the burner was not capable enough) then the larger boiler would be required.
The problem with starting a triple (or any compound engine for that matter) extends from the fact that the engine may STOP with the HP valve gear in such a position that the STEAM ports are CLOSED....... (a few degrees either side of TDC or BDC).... in these instances the engine will not start becouse the steam from the boiler cannot enter the engine and, since the engine was stoped, there would be no (or virtually none) available exhuast steam from the HP cylinder to enter the IP cylinder, or from the IP cylinder into the LP cylinder.
A simple expansion engine (multi cylinders all operating at std boiler pressure) does not suffer from this, since all cylinders are connected directly to the boiler steam feed.
SIMPLING valves are used to turn Compound engines into SIMPLE expansion engines (hence the name), for the purposes of starting them under such conditions and, just as you have said, they are only used to inject steam directly in to the IP and or/LP steam chests in order to drive the crank round to a position where the HP ports/valve is opened... at which point this then takes over and the SIMPLING valve/s can be closed.
On a small model engine, these could simply consist of a servo driven steam valve (operated from a spare channel with which you could momentarily inject steam to get going.... once running you would immediately close them again.
On FULL size ships/vessels... these may or may not include a pressure reducing stage (often included to avoid over pressure damage to the engine) and can be either manually operated (on smaller vessels) or mechanically/hydraulically linked to the normal regulator on larger vessels.
Regardless of the exact mechanism, the engine valve gear would always be placed into full FORWARDS or REVERSE (giving maximum cut-off) before attempting the start.
Once fully under way the valve gear can be backed off (notched up) to reduce the cut-off in order to get the best use of expansion from the steam.
Hope this helps explain things a bit more.
Best regards.
AlexC
