Author Topic: 2 operations 1 stick  (Read 3192 times)
cassf1
« on: July 29, 2009, 11:35:10 pm »
Hi
I'm wondering if its possible to operate two servos from one stick. This is what i want to do
move stick left drops hatch 1 via servo 1
move stick right drops hatch 2 via servo 2
Transmitter is futaba 6exa
thanks for any replies
Ghost in the shell
Re: 2 operations 1 stick
« Reply #1 on: July 30, 2009, 12:20:22 am »
cass how you would work it is have the servo work a latch, with hatch 1 working the front half of the arm, hatch 2 working the other half.
Go Nuclear!  you'll love it
Umi_Ryuzuki
« Reply #2 on: July 30, 2009, 04:14:28 am »
Two hatches can be done with one servo.
Run a brass wire through from each end of a servo arm to the hatch catch.
When you want to release hatch one, the servo pulls back on the wire to
hatch one, and it lets go of the catch. At the same time, the wire to hatch two
would just extend a little further through the catch at hatch two.
The same thing would occur if you wanted to release hatch two first....
Now if you wanted separate servos to open, and then close the hatches,
that could probably be done with cams and springs, in a similar fashion.
Bunkerbarge
« Reply #3 on: July 30, 2009, 09:50:31 am »
You could also use the servo to operate two microswitches, one on either side and each used to operate another small motor such as a servo motor.
gromarlie
« Reply #4 on: July 31, 2009, 02:28:46 pm »
Or to answer the actual question use a Y lead between the reciever and the 2 servos :-))
« Reply #5 on: July 31, 2009, 09:33:17 pm »
If you want to operate then in unison, yes.
If you want to operate them independantly, unfortunatley not.
« Reply #6 on: July 31, 2009, 09:42:00 pm »
The P91 switch from ACTion electronics might do it. Especially if linked to the P96 servomorph in switch mode.
http://www.action-electronics.co.uk/switches.php
http://www.action-electronics.co.uk/mixers.php
I have no personal connection with, I have just always found Dave to be extremely helpful. And I happen be trawling through the website at the moment looking for bits for myself.
From the website
P91 HI-LOAD TWIN SWITCHER
£ 28.00 Incl VAT
PIC-based; 2 separate switched circuits from one proportional R/C channel. Each of the two outputs can be driven as either Latching (Memory) or Non-Latching (Momentary) switches. Adjustable switching points; 10Amps (peak 20A) on each circuit. Designed especially to operate motorised functions such as fire-monitors, bilge pumps and twin-motor bow-thrusters; will also switch 'conventional' loads such as lights and sound simulators. Case size is 63 x 43 x 25mm, and connections are via screw-terminals. Limited functionality when operated from ON/OFF switched channels [e.g. retract gear] - ring for details.
P96 SERVOMORPH
£ 12.00 (£ 11.00 each for 3+) Incl VAT
Connect P96 between the receiver and a servo and you can adjust the travel up to around 160� and the end-to-end speed down to 30 seconds. In Switch mode you can run the servo from one end to the other just using a simple manual or RC switch. Couple two or more in series and you have the perfect driver for cranes, gun turrets, cargo doors and hatches, boat davits - in fact its applications stretch nearly as far as your imagination!
Telephone: (UK) 0115 9607951 (9.00am – 5.30pm Mon – Thurs, 9:30am - 2:00pm Friday. Closed Weekends).
Please respect our domestic life and don’t ring outside these hours.
cassf1
« Reply #7 on: August 01, 2009, 08:40:35 pm »
Thanks for all your answers i will give it some thought as to which way i go from here
Page created in 0.033 seconds with 21 queries.
