Author Topic: S boat prop shafts  (Read 3201 times)
Leaky
S boat prop shafts
« on: August 11, 2009, 09:47:14 pm »
I bought a set of prop shafts for my Italeri 1/35th S boat and i drilled out the prop shaft housings to suit,but i followed the line of the housings exactly as it looks as though they should be drilled at a steeper angle and my shafts are too short.This i don't mind i can either make or buy longer ones to correct this,has any one got any interior photos of their builds? so i can work out positioning of motors/batteries to suit my shaft cock up
badly raised and ill mannered.
keef666
Re: S boat prop shafts
« Reply #1 on: August 12, 2009, 09:22:05 am »
are these any good to you, i know others have done them different, but at the time i used steel rod and copper tube, the inner is around 12" and two outer around 14".
Leaky
« Reply #2 on: August 12, 2009, 10:11:39 am »
Thats perfect your shafts come out of the hull where mine do cheers!
Wasyl
« Reply #3 on: August 13, 2009, 01:54:24 pm »
I,was going to get the Italeri boat but opted for the Robbe,only because it was already built,as i,m not a very good builder,and because it had a super camo paint job,Baltic Flotilla i,m told see pics
Wullie
keef666
« Reply #4 on: August 13, 2009, 11:21:10 pm »
 And i thought i was the world worse model maker, well as long as you have fun in the water with it, who cares, not me
 Keith
allnightin
« Reply #5 on: August 17, 2009, 10:02:44 pm »
I got the SHG shaft set which had the same problem of being too short because they are at a steeper angle so that motors and batteries can be shifted further aft.  This is the Dave Abbot design that is due to be published in Model Boats soon.  SHG offered to do a lengthened set to suit my requirements for the scale layout - I haven't had the new ones back yet.
Page created in 0.651 seconds with 21 queries.
