Author Topic: WW2 HMS Illustrious  (Read 4950 times)
g6hfk
WW2 HMS Illustrious
« on: August 21, 2009, 02:46:12 pm »
I have just aquired a hull and plan for world war 2  HMS Illustreious aircraft carrier, it is about four foot long, anyone got any idea to get suitable aircraft from, swordfish would be ideal
 Les g6hfk
Re: WW2 HMS Illustrious
« Reply #1 on: August 21, 2009, 02:56:18 pm »
WW2 Illustrious Length: 743.75 ft (226.70 m)
Therefore 4ft model will be about 1:186 scale, odd size ?
John R Haynes
« Reply #2 on: August 21, 2009, 03:43:38 pm »
Would think 1/192 will suit ?A more conventional scale. I can supply a Walrus at this scale but who could supply Carrier aircraft ? A search on the net may produce results .
g6hfk
« Reply #3 on: August 21, 2009, 07:08:52 pm »
           Thanks for the replies, I think I had better measure the beast and start again
Rex Hunt
« Reply #4 on: September 02, 2009, 10:56:34 am »
Might be worth asking the question on the Modelwarships uk forum in the aircraft carriers section.
I am sure someone showed me Albacores Swordfish and Wildcats for a HMS Victorious he is building.
Can't remember who though sorry.
Rex
« Reply #5 on: September 03, 2009, 09:59:22 am »
Deans Marine do loads of WW2 carrier aircraft 1:96 scale though.
http://www.deansmarine.co.uk/shop/index.php/cPath/52_55
rsm
« Reply #6 on: September 03, 2009, 10:36:30 am »
You can get 1/200th Grumman Avengers here:
http://www.gpm.pl/eng/index.php?akcja=produkt&edycja=4223
You have to make them up yourself from lasercut card, but they are quite cheap.
Roger.
Jimmy James
« Reply #7 on: September 13, 2009, 09:53:32 pm »
I think Illustirous Carried the Blackburn Skua (Fighter / Dive bomber) with the 890-hp Bristol Perseus XII sleeve Valve engine they were withdrawn operational service in 1941 and were replaced with Fairey Fulmars (800 & 806 Squadrons) and Hawker Sea Hurricanes (No# 801 & 803 Squaderons) Fairey Swordfish from No's 813, 815, 819 & 824 Squadrons also served on board Illustrious ... Albacores were carried on board HMS Formidable in 1940-41 in 42/43 they were replaced by Fairey Barracudas (no 810 squdron on Illustrious in sept 43)or Grumman Avengers ....Flight trials for the Fairey Firefly were carried out on board Illustrious at the end of 1942 in Late 1941 a Mk VB Spitfire fitted with an arrester hook was flown on Illustrious for compatibility trials( This later becane the Sea Fire .... So it would seam you have a vast choise of aircraft you could display on deck
Hope this is some help to you
Freebooter
Kings Lynn
Page created in 0.33 seconds with 21 queries.
