Author Topic: MMB Motors  (Read 4250 times)
Marks Model Bits
  • No Mustang Mark
  • http://marksmodelbits.com/
    • Marks Model Bits
MMB Motors
« on: August 27, 2009, 02:53:55 PM »
Having received requests for specs on my 900 motors and my new 755 motors I thought it might be a good idea to list the specs in a new topic.
I will soon have the new website I am currently working on up and running :-)) :-)) :-))
MMB 900 motor:-
Body:                           52mm dia  85mm long
Shaft:                           single end 5.0mm dia ballraced
Commutator:                 12 pole,
Voltage:                       6 - 24 volts (Please note over 18 volts the motor will need to be watercooled)
No load RPM:               6500 RPM on 12 volts
No load current            1.1A
Price 30 each
RS- 755 motor
Body: Length  87mm
Diameter:   42mm
Shaft diameter:   5mm
Voltage:  6 - 12 volts
Commutator:    5 pole
No load speed:  4400 RPM on 12 volts
No load current:   0.3 amps
Price 15 each
Mark.
Perkasaman2
Re: MMB Motors
« Reply #1 on: January 27, 2010, 02:20:25 PM »
Hi Mark, can you tell me the weight of the hi torque MMB900 and do you supply a motor mount to install? (A pic and price would be really helpful.)  :-)
Marks Model Bits
  • No Mustang Mark
    • Marks Model Bits
Re: MMB Motors
« Reply #2 on: January 27, 2010, 02:50:27 PM »
Hi, the motor weighs approx 600g. I supply a machined aluminium motor mount complete with stainless steel Allen head screws for these motors for 5 each.
http://www.marksmodelbits.com/
Perkasaman2
Re: MMB Motors
« Reply #3 on: January 27, 2010, 03:11:02 PM »
Many thanks Mark  ok2
wombat
Re: MMB Motors
« Reply #4 on: March 06, 2010, 09:24:37 AM »
I can vouch for the 900 - a lovely motor.
With its slow running capability perfect for a large or even a medium sized boat
Wom
captain ron
Re: MMB Motors
« Reply #5 on: March 07, 2010, 10:53:22 PM »
Hi guys,
I've got 2 No MMB rs755 motors .Do you think they will be okay driving 2 No 65mm kort props in nozzles???? In a nantoo hull for tug towing????
Ron
