Author Topic: Ebay push tug hull  (Read 4832 times)
das boot
Ebay push tug hull
« on: August 29, 2009, 10:34:00 am »
Guys, attached are a few pics of the push tug hull I bought from ebay. You'll notice it's not exactly straight along the hull sides (I did get a partial refund on the cost because of this)...so, any ideas as to the best way to straighten it out?
Sorry about the poor quality pics, camera batteries need a charge.
Ta
Re: Ebay push tug hull
« Reply #1 on: August 29, 2009, 10:39:58 am »
Hi Rich
You could try clamping the sides together with sturdy timber lengths and then apply a 'Hot air gun' gently. Let it cool and then do it again. Leave the clamps on for a day and it might solve your problem.
Hope this helps
Ken
DARLEK1
« Reply #2 on: August 29, 2009, 10:40:29 am »
Easy answer, frame it out inside.
 I hope this helps?
 Paul... ok2
das boot
« Reply #3 on: August 29, 2009, 10:58:16 am »
That's what I did consider Paul, frame it on the inside with 1/4" x 1/4" hardwood, clamping everything up and keeping my fingers crossed that it straightened itself out.
Ken, don't have a hot air gun, but I have the good woman's hairdryer on standy. She'll not know I used it, she's in Canada....
Thanks chaps...
snowwolflair
« Reply #4 on: August 29, 2009, 05:25:40 pm »
Strap wood to either side and fill with boiling water, then let it cool to avoid distortions - then frame it.
andyn
« Reply #5 on: August 29, 2009, 07:12:41 pm »
Make sure the deck you fit is striaght and wedge it in.
snowwolflair
« Reply #6 on: August 29, 2009, 08:30:44 pm »
Only for slight bends, I have seen a model tear itself appart because to much force was stored up.  when ir went it took modt of the deck of  :o
das boot
« Reply #7 on: August 30, 2009, 04:20:02 am »
hmm...some interesting replies there, thanks guys.
The problem has sort of solved itself...the chap who moulded the hull is a member of Mayhem, he read this and is in the process of moulding another one for me, hopefully with straighter edges this time!
Thanks for the input chaps....watch this space!!!
Klunk
« Reply #8 on: August 30, 2009, 06:14:57 pm »
i will start the bidding at 50p for the old hull lol........see how this bidding goes!
full time penguin
BlazingPenguin
« Reply #9 on: September 07, 2009, 05:11:08 pm »
50p bid.......!
das boot
« Reply #10 on: September 07, 2009, 05:14:08 pm »
£10 plus p&p....take it away.
stevext
« Reply #11 on: September 08, 2009, 04:10:06 pm »
Hi
if the sides have bowed in a little it might just be that the resin had a little too much catalyst put in it causing it to shrink a little whilst curing.Nothing much to worry about but as you've got a new one on it's way i'd vote for framing it inside as well.I'm going to try and post some pics of a 24" Damen style  harbour tug i've done the plug for on here tonght and see what the mayhemers think!
Good luck with the build.
cheers
stevext
Big Ada
« Reply #12 on: September 08, 2009, 06:15:51 pm »
Cut a 1/2" Ply deck, making it a tight fit and tap it in, then apply epoxy to seal around the inside.
Thats what I did for my Springers.
Len.
Page created in 0.176 seconds with 22 queries.
