Hi With ref to the max. current drawn by a motor when stalled. If you measure the RESISTANCE of the motor with a multimeter then when stalled ie stopped from turning the current will be the battery voltage divided by the motor resistance. I measured a MFA Hummingbird 15 motor it was 0.15 ohms resistance, so on a 6volt battery is max. current would be 40amps if my maths is right. As for the running current, its roughly proportional to the torque on the motor plus the no load current. This way gives you a ballpark current, without the need to overload the motor in question. As for fuses I use one just below the max rating of the ESC. fuses are not there for normal running but to limit damage when things go wrong. If a fuse blows you may have the inconveniance of having to recover a 'dead' model, but with no fuse, it may be recovery of a burnt up dead model, (is that cremated?)
