Author Topic: How is your transmitter set up for sail control  (Read 12749 times)
Dazzle69
Re: How is your transmitter set up for sail control
« Reply #25 on: March 03, 2011, 10:57:26 am »
TriumphJohn
If you put a 'pulley' on the servo arm, and lead the sheets to a fixed point near where the sheeting line exits the hull, you will gain twice as much movement of the sheets for the same amount of servo arm travel.
Eg, 3" sail arm travel = 6" sheet travel.
Just an idea.
Would also give the sail arm servo 1/2 the torque though.
Daz
May only the bits DESIGNED to get wet get wet.
Page created in 0.018 seconds with 19 queries.
