Author Topic: Need for(a bit of) speed...  (Read 12471 times)
andyn
Re: Need for(a bit of) speed...
« Reply #25 on: September 27, 2009, 07:31:02 pm »
This hull is designed for surface drive. Putting a submerged drive setup on it will most likely cause it to spin a lot.
das boot
« Reply #26 on: September 27, 2009, 08:00:16 pm »
hmm...ok, thanks.
« Reply #27 on: September 27, 2009, 08:02:54 pm »
There you go Rich,
Get the plastic out and hope it doesn't melt!!!
andyn
« Reply #28 on: September 27, 2009, 08:24:55 pm »
See what the electra lot have for sale, they're bound to have something.
das boot
« Reply #29 on: September 27, 2009, 08:33:32 pm »
There you go Rich,
Lucky the good woman is half way across the other side of  the world at the moment, Bob!!!
« Reply #30 on: September 27, 2009, 08:56:39 pm »
Rich,
But now you aren't going for  (a bit of) speed, a lotta speed.
All that specialised equipment, think she just might be a dynamic flyer!!!!
« Reply #31 on: September 27, 2009, 09:04:06 pm »
Rich,
Just to cheer you up, nice brushless motor for £109-00 and speed controller for it at only £250-00!!!
Check out: http://www.astecmodels.co.uk/catalog/
But be sitting down first!!!
andyn
« Reply #32 on: September 27, 2009, 09:21:44 pm »
A nice cheap one then ;) How about this then?
http://www.aeromicro.com/Catalog/axi__5330_double__outrunner_brushless_custom_double_motor_axi5330double_5398643.htm
FullLeatherJacket
« Reply #33 on: September 27, 2009, 11:02:14 pm »
'Uggett
Why don't you just flog the hull and buy a Club 500 instead? This is getting a bit exotic.....................  :o
FLJ
das boot
« Reply #34 on: September 28, 2009, 04:52:48 am »
'Uggett
FLJ
Exactly what I was thinking, boss...to think all I wanted was a little something to go play with on a Friday afternoon with the lads down on the pond, and Andy has me spending a small fortune.
I think I'll maybe stick to drilling and filing 500 and something flood holes in U-441....
Rich(not at this rate....)
nick_75au
« Reply #35 on: September 28, 2009, 05:51:43 am »
Ive built one of Glynn Guest's boats, its a crashboat about 20 inches long, with $50 AUS (20 Pounds maybe) motor and speed control, brushless, 10 cell NiMH, it does 25 Kph which is more than enough for a bit of fun, its sub surface drive, straight shaft and only spins out if I REALLY push it.
What you want to do can be done, If you really want to be cheap buy/obtain a cheap cordless drill, motor, speed control and batteries and will only take a little time to convert the trigger into a quasi mechanical/electronic speed control, no it wont be a rocket but it will be fun.
V bottom boats have been running subsurface drive for a loooooong time with good results before all this surface piercing, flexible drive, latest technology :P stuff came out
Nick
martno1fan
« Reply #36 on: September 28, 2009, 09:41:27 am »
Rich have a look at this setup then go have a look in his shop and get what you need,his prices are pretty good and hes pretty good on shipping too.
Mart
http://cgi.ebay.co.uk/25-deep-vee-ARTR-with-motor-and-ESC-racing-spec-red_W0QQitemZ300348683654QQcmdZViewItemQQptZRadio_Control_Vehicles?hash=item45ee2d3586&_trksid=p4634.c0.m14.l1262
das boot
« Reply #37 on: September 28, 2009, 04:46:12 pm »
This is beginning to frighten the wotsname out of me....the cash outlay, the speed of the projected thing...it was only meant to be a quick 'throw it together and go play' build, and now I'm looking at brushless motors, watercooled everything, rudders and stuff hanging off the back...enough, guys...enough!!!
I'm going to stick to drilling and filing flood holes in U-441, it's considerably cheaper and less strain on my poor old wallet, let alone my old ticker.
Anybody want to buy a unused Zoom2 hull?
omra85
« Reply #38 on: September 28, 2009, 08:08:14 pm »
Hi Rich
Looking at the inside of the blue boat in your pics, I suspect it is a "deep V" hull unlike the Silak which was designed for multi and was a shallow V.
If you use a submerged shaft, it will work, but the extra thrust you will get from the downward angle of the prop will lift the boat too high - the faster you go, the more unstable it gets. With a flexi drive which exits parallel to the hull and at the bottom of the hull "V", the thrust is taken straight back and is more efficient for speed or low powered motors.
If you get a submerged drive set up in the right hull, then you will have sharper steering, but for your hull, I think not.
Can't help with the 'leccy' side though - not my area I'm afraid.
Danny
(if it don't make a loud noise and a bad smell - it's broke!)
nick_75au
« Reply #39 on: September 29, 2009, 05:48:34 am »
Rich,
Notice all the posts recommending this and that are from IC boys.......
10 cells, 700 motor, subsurface, straight shaft, one of those common brass rudders and it will go fine :-))  for what I think you want ;)
Nick
As a note to my first post the boat with the 600 motor is 800 mm long a  bit bigger than the Zoom
HS93 (RIP)
  • I cannot spell , tough
« Reply #40 on: September 30, 2009, 04:18:17 pm »
nick_75au has the right idea for a SPORTS BOAT start with less cells and add some more if you want to go faster.go for a forward only speed controller as they are cheaper and you wont swamp it going back to fast also go for a 40/60 amp min that way you will loads of leeway for wrong prop choice. it will make a nice fun boat.Oh and keep it light as you can.
Peter
das boot
« Reply #41 on: September 30, 2009, 04:36:18 pm »
Gentlemen, time to confess....I've sold this hull to someone on this forum who knows how to get the best out it, it was getting waaaay out of hand, and far too expensive for me.
I've just bought another fast(but not THAT fast)electric, so eyes down for a posting when it arrives. This one is practically a complete kit out of the box, and is designed for a common or garden 540 motor, eight cells and a submerged drive.
Thank you all for all your assistance.... :-))
das boot
« Reply #42 on: October 02, 2009, 07:10:31 pm »
The kit should arrive tomorrow morning, so I'm reliably informed. Stand by...
das boot
« Reply #43 on: October 03, 2009, 09:15:24 am »
