Author Topic: JJC Electronics  (Read 3706 times)
destroyer42
JJC Electronics
« on: October 18, 2009, 08:20:05 pm »
Hi Fellow boaters,
Is there any one who can fix the old JJC smoke units?
I think it could be the module that not working correctly. Fan works no smoke. It belongs to a friend who is retired and I dont think he could afford a new one.
Destroyer42
ray123
  • mary marie cygnus gm33
Re: JJC Electronics
« Reply #1 on: October 18, 2009, 09:05:08 pm »
hi colin  why dont you bring it to the next boat meeting & let larry have a look  he is very good with eletronics  regards ray
Martin [Admin]
Re: JJC Electronics
« Reply #2 on: October 18, 2009, 09:09:35 pm »
Did Hunter System used to do some repairs?
"This is my firm opinion, but what do I know?!" -  Visit the Mayhem FaceBook Group!
Umi_Ryuzuki
Re: JJC Electronics
« Reply #3 on: October 18, 2009, 09:11:33 pm »
Do take a moment to make sure the water level is correct.
I had one gentleman contact me regarding a non working JJC unit, and
I told him to try adding another 60 ml of water... It went right back to working.
Just be careful not to over fill it, as any water through the fan will ruin the fan.
Bartapuss
  • Deltic's Rule OK!
Re: JJC Electronics
« Reply #4 on: October 25, 2009, 09:23:16 pm »
Try hooking up the piezo vapouriser to a 24v supply directly to see if that still works, if it does then its the control board, however if this is faulty some of the components on there are long obsolete.
Every time I learn something new, it pushes something old out of my brain - I says wot I likes and I likes wot I say!!!
Umi_Ryuzuki
Re: JJC Electronics
« Reply #5 on: October 26, 2009, 03:08:50 am »
The vaporizor in the JJC was an AC powered unit. the circuit board had a coil on
it that would vary the voltage to the vaporizor from 1 - 54 volts AC.
andywright
    • Windpowersails
Re: JJC Electronics
« Reply #6 on: December 01, 2009, 11:18:26 am »
Doesn't sound like much chance of repairing Old Smokey then, I just thought I'd try mine before advertising it to sell, but it doesn't make smoke anymore.
Navigational Aids vessel Master. Old Conway 70-72
Marks Model Bits
  • No Mustang Mark
  • http://marksmodelbits.com/
    • Marks Model Bits
Re: JJC Electronics
« Reply #7 on: December 01, 2009, 11:40:59 am »
I have repaired a few of these old smokey units by converting them to the same spec as my Foggys, what you get is a JJC box with Foggy internals.
Mark.
I HAVE NOT FAILED, I HAVE FOUND 1000 WAYS THAT DON'T WORK.!!!!
787Eng
Re: JJC Electronics
« Reply #8 on: December 01, 2009, 12:41:34 pm »
Or fix it yourself, the fogger module available from your logcal Maplin.
http://www.maplin.co.uk/Module.aspx?ModuleNo=35215
Mark
