Author Topic: water proof servos  (Read 3024 times)
tony23
water proof servos
« on: October 20, 2009, 06:40:17 pm »
Is it possible to buy water proof servos I was told of a futaba servo but can only find a helecoptor 'dustproof' casing type servo?
ministeve
  • washing the decks!!!
Re: water proof servos
« Reply #1 on: October 20, 2009, 07:12:29 pm »
a bit of self amalgamating tape around the bottom works well unless the top of the servo is exposed i know of nothing that would stop water ingress and still allow the servo to move
what are you useing the servo in
knoby
« Reply #2 on: October 20, 2009, 08:08:41 pm »
traxxas make waterproof servos in 3 different sizes, have a look on ebay, they are around £13. I have used a micro 1 as a steering servo in a eco 3 fast electric, but did find it a little slow for that. I'm not sure how waterproof they are, I suspect that water would seep through the output shaft if it was fully submerged for any length of time, but the fast electric has a fair amount of water slopping around in it at times & the servo never failed.
cheers Glenn
omra85
« Reply #3 on: October 20, 2009, 10:24:47 pm »
Futaba have just brought out a new one - S3014 - claimed to be waterproof
http://www.clevelandmodels.co.uk/index.php?cPath=33&osCsid=0ca835b43298dcfd0ecff894f3395398
Danny
tony23
« Reply #4 on: October 20, 2009, 11:09:54 pm »
what are you using the servo in
I have an IOM yacht which I sail in all conditions sometimes in a gale and it's not unusual for the boat to nose dive into the water on the down wind leg with water completely covering the boat so there will always be a little water in the hull after sailing but I have just had a brand new high torque servo (£38) die on me and it looks like water has crept through the casing joint or the screw heads/holes into the circut board. I have smeared the joints with some Vaseline but it looks like it got in somewhere I know a servo cannot be totally water proof but one that's been built to with stand some water will go a long way.
w3bby
« Reply #5 on: October 23, 2009, 02:47:25 pm »
Waterproof your servos with Plasti Dip http://www.plastidip.co.uk/index2.cfm?page=products&prodId=1 and an O-ring under the arm.
Method shown here http://www.societyofrobots.com/actuators_waterproof_servo.shtml (scroll down a bit...).
Used this on an exposed servo in an open waterjet hull without any problems.
It comes off easily if you need to get into the servo at a later date.
tony23
« Reply #6 on: October 23, 2009, 09:19:35 pm »
I found that site on YouTube a couple of nights ago and have tried it using a clear high modules silicon sealant on a new servo, I took the yacht out today for a sail and it's works perfectly although I yet to find out if any damp gets in.
I have also ordered a Futaba S3014 to try out.
With its 6.5Kg/cm torque, high speed and ball bearing supported output, this standard size, water-resistant servo is ideal for a variety of boat and yacht applications.
andyn
« Reply #7 on: October 24, 2009, 05:32:20 pm »
The 3014 has been out ages. No servo is ever going to be completely waterproof, it's got holes in it.....
What I would do is to fill it with Dow Corning 7 silicon grease.
Page created in 0.153 seconds with 21 queries.
