Author Topic: scaling plans  (Read 1545 times)
class37
scaling plans
« on: October 24, 2009, 09:53:05 pm »
Hi all,
can I just check that I have something right ?
I have read loads of the posts on this, and I think I have got it right, but just want to check before I start copying.
I've just received a set of ship plans at 1/100 scale, and I want to photcopy them to 1/72.
am I right in thinking that to get the new setting I divide the old scale [100] by the new scale [72] to get a ratio of 1.38 recuring.
so I copy the plans at 138%, and this should result in 1/72 scale plans.
then take a known dimension from the data sheet, measure on the original 1/100 scale plan, and do the same on the 1/72 scale plan, and the resulting measurements should be at 1/100 and 1/72 of the original real dimension.
many thanks in advance
cheers
alan
gribeauval
Re: scaling plans
« Reply #1 on: October 24, 2009, 10:11:14 pm »
Close enough. 8)   (It should be 138.888885%)
Download this little program it makes it easy and does all the calculations for you.
True Lifeboat Nutter!!
class37
Re: scaling plans
« Reply #2 on: October 24, 2009, 10:24:15 pm »
Hi Mike,
many thanks for that.
I think the copiers at work on go to 1%, but with my building that should be close enough !
just going to check out that link then I'll have a go at the plans.
good thing it's an extra hour at work tonight !
cheers
alan
class37
Re: scaling plans
« Reply #3 on: October 25, 2009, 01:44:11 am »
just to add all came out great, and new set of working plans is now to hand.
thanks
alan
