Author Topic: Hull prep for painting question.  (Read 2962 times)
Bugsy
« on: October 26, 2009, 08:40:36 am »
My scratch-built, one metre hull, epoxy and cloth over balsa planking is now ready for painting. After applying a sand-coat of epoxy I have now rubbed it down with 180 wet & dry.
I have, following Stavos' thread got spirit wipe but am just wondering about this.
Is it necessary or advisable to use a 'plastic' etch-primer before spray putty, primer and finish coats?
Thanks.
gondolier88
  • www.coniston-regatta.co.uk
    • Coniston Regatta
Re: Hull prep for painting question.
« Reply #1 on: October 27, 2009, 07:21:26 pm »
Hi Bugsy,
Not sure what you mean by 'etch' primer- etch primer is only for metals, not for plastics.
However as a base coat you will need to use a plastic primer- most, me included, use the Halford's ones- they do a Red Oxide plastic primer which can be used as a good antifouling representation and the grey plastic primer can be used as a base for all other colours.
Greg
Bugsy
« Reply #2 on: October 28, 2009, 07:16:49 am »
Hi Greg,
This is the stuff I'm on about.
Its a, clear, thin etch coating for automotive plastic.
gondolier88
    • Coniston Regatta
« Reply #3 on: October 28, 2009, 05:33:57 pm »
If you can get the paint from the same manufacturer then you should be ok- it should state what plastics it can be used on on the back of the can.
Greg
Page created in 0.062 seconds with 21 queries.
