Author Topic: Help Neededre Radio Gear  (Read 2491 times)
UKJonathan
« on: October 31, 2009, 03:39:10 pm »
Hi a newbe here
                      I'm ready to fit radio gear into my boat I have a Futaba FP 6NPK /FP-6NFK, transmitter, and its supposed to be FM. PCM system with two recievers one is a duel conversion  FP-R 138DP, and the other is Duel Conversion  FP-R128DF What I want to know is this just for areoplanes, if so I will buy a new set up
any help please
Jonathan
Re: Help Neededre Radio Gear
« Reply #1 on: October 31, 2009, 04:39:27 pm »
H Jonathan,
I'm not familiar with all the designations of Futaba, but what really matters is the frequency range/band. If your equipment is 35Mhz then yes it is just for aeroplanes and you will have to buy new equipment.
Both 40Mhz and 27MHz can be used for surface models (land and sea). The newer 2.4Ghz equipment can be used for both surface and air but won't work with submarines.
HTH
Doug
gribeauval
« Reply #2 on: October 31, 2009, 05:19:39 pm »
Hi Johnathan, you will need new gear, either 40mhz, 27mhz or 2.4ghz, as your set is 72mhz and not legal in the UK.
True Lifeboat Nutter!!
wideawake
« Reply #3 on: October 31, 2009, 05:45:05 pm »
Sadly this is true for boats, 'planes and ground vehicles.
http://manuals.hobbico.com/fut/6nfk-6npk-manual.pdf
confirms the frequency bands available for this set.
HTH
Guy
UKJonathan
I Bought New Radio Gear
« Reply #4 on: November 01, 2009, 10:39:02 pm »
I bought new radio gear in the end 2.4ghz set up. So thanx guys for your help
Peter Fitness
« Reply #5 on: November 01, 2009, 10:44:03 pm »
What make of 2.4ghz set did you buy?
Peter.
