Author Topic: Sea sheperd plan help  (Read 1803 times)
pobolycwm
« on: November 04, 2009, 08:56:13 am »
As i cant find anyone offering a template making service i am going to have a go myself. On the following image when drawing the frames do i go to the red line or the green line, also is the curve at the top the camber of the deck. any help appreciated as sproglet wants to start within the next week
cheers
pob
Re: Sea sheperd plan help
« Reply #1 on: November 04, 2009, 11:26:54 am »
Pov....I tend to consider that hull frames would be limited to the RED  level......& that bulwarks above that in GREEN would be additional to the hull structure
A further detailed understanding of the hull structure is required....Derek
longshanks
« Reply #2 on: November 04, 2009, 10:11:56 pm »
Sorry - disagree, the Sea Sheherd has no bulwarks!
The area between the red and green lines is marked on the plan as a knuckle. On the actual boat its a rubber fender.
Check this link - at the bottom of the article there are some very good pics.
http://www.maritimejournal.com/archive101/2004/june/vessel_launch_macduff_shipyards_ltd_-_sea_shepherd/macduffs_new_pilot_launch_for_aberdeen_harbour_board
The curve on the top of the section plan is the sheerline or deck edge.
The camber height is shown on the side elevation. I would be tempted to suggest as this is a first model that you ignore the camber and make the deck flat, makes life alot easier when fitting out the deck area.
Hope this helps
longshanks
Page created in 0.893 seconds with 21 queries.
