Author Topic: Glues, adhesives and stuff!  (Read 1159 times)
tinbum
« on: November 10, 2009, 08:17:19 PM »
Hi, we're just starting our 1st build. The instructions mention CA, thick CA and ABS cements. I think CA is superglue, but am not sure, and I don't know what ABS cement is.
Help! :embarrassed:
Jani
Re: Glues, adhesives and stuff!
« Reply #1 on: November 10, 2009, 08:58:49 PM »
CA (Cyanoacrylate) is indeed superglue. It generally comes in three thickness (altho some brands offer more choices); thin (most brands thinner than water), medium (somewhat more viscous than water) and thick (thick but not like gel or paste). There exists varieties for some sensitive materials, such as styrofoam (useful to remember).
ABS (Acrylonitrile Butadiene Styrene) cement is basically thick filler that melts ABS for adhesion like thinner variants that may be used as glue. This one most definitely needs very good ventilation, methyl ethyl ketone is not good for you. You will find various brands by simply searching/googling for "ABS cement".
Hope this is more or less what you were looking for.
^Jani
« Reply #2 on: November 10, 2009, 09:05:18 PM »
Check out this site. All the information yiou need. http://www.deluxematerials.com/
« Reply #3 on: November 10, 2009, 09:15:28 PM »
From Model Slipway hints and tips.
  ADHESIVES
Adhesives may be in tube form (polystyrene cement) or in liquid form such as Humbrol Liquid Poly or MEK (methyl ethyl ketone) which is best applied with a brush. The technique is to apply a few drops of the solvent and the glue will run down the joint by capillary attraction. The following glues are recommended:
Fibreglass to plastic: two-part epoxy (Devcon, Araldite, Speed Epoxy) - 10 min. or 1 hour.
Plastic to plastic: ordinary plastic solvent (Revel, Liquid Poly, Slaters, MEK).
Whitemetal to whitemetal: two-part epoxy (5min.) or thick superglue (Pro-Bond, MFA etc.)
Whitemetal to plastic: two-part epoxy or thick superglue.
Wood to plastic: two-part epoxy, thick superglue or contact adhesive.
Brass to plastic: R/C Modellers craft glue or thick superglue.
Rubber Fendering: contact adhesive (UHU, Bostik).
Window glazing: Weldbond, RC Modeller's Craft Glue or clear contact adhesive (UHU, Bostik etc.)
http://www.modelslipway.com/
tinbum
« Reply #4 on: November 11, 2009, 09:24:52 AM »
Thanks guys. I guess I'll put the Prit-stick away then!
