Author Topic: Receiver voltage  (Read 1990 times)
Robs
Receiver voltage
« on: November 14, 2009, 08:52:51 pm »
Hi y'all, probably a silly question but can I use a 7.2v battery pack with a 6v receiver with BEC? I want to keep weight low and use the power battery for the motor to run the rx. Cheers, Rob
Re: Receiver voltage
« Reply #1 on: November 14, 2009, 09:01:26 pm »
If your speed controller has a BEC and you use it the answer is yes.
knoby
« Reply #2 on: November 14, 2009, 11:03:44 pm »
Hi Robs.
If your receiver has a bec circuit built in theres no problem, if not as Dicky says you can use an esc with a bec built in. Alternatively you can use a separate bec circuit.
cheers Glenn
Robs
« Reply #3 on: November 16, 2009, 11:04:16 am »
Thanks guys, I can get on with the build now. Cheers, Rob :-))
Page created in 0.167 seconds with 21 queries.
