Author Topic: Fast Conical Launch Design  (Read 6546 times)
gondolier88
  • www.coniston-regatta.co.uk
    • Coniston Regatta
« on: November 15, 2009, 02:05:21 pm »
Hi All,
Thought you all may be interested in my designs for a full size 30ft steam launch. %)
It is still in the design stage, had more pressing matters to deal with, and probably won't get started for the next 4-5 years, however a model will be built to test the design.
It started out as having the design brief from myself of;
1- Must be fast, light and efficient hull
2- Easy to steam one handed
3- Seating for 9/10 passengers
4- Must have a cabin (swmbo!), prefer lighter open launches myself, but hey they have advantages, and i'm thinking of 3mm teak veneer over aluminium frame with foam sandwich giving traditional finish but negligible weight disadvantage
5- High speed quiet single acting engine with useable power range
6- As large a pitch as pos' with a fairly small diameter giving fast pickup- high revs for full power and shallower draft
Since doing the hand drawings last year I’ve messed around with the hull design on DelftShip and managed to get it down to a negligible resistance (almost nothing, didn’t know how I had the patience to tinker that much!) using a more conical hull under the waterline with almost a constant entry angle for the entire length of the hull for’rd, also kept displacement to 1.5tons which gives a decent power to weight and power to length ratio of 1.2 would give an engine of 35hp.
I’ve included my hand drawings and also the Delftship renderings- interesting comparison from my original design by hand with no calculations just aesthetically designed by eye and then Delftship’ed to suit the aesthetics and fill the rest of my brief.
Also I’ve included my engine design, clutching at straws really, it is loosely based on the Willan engine designs, normally three cylinder, high speed single acting engines with a similar throttle to the cheddar integral throttle/reversing block. However this design has never really been proved- it relies on having the best seal between the steam side and the crank-case possible. However, even if it was changed to double acting I would like to keep the IC engine inspired no piston rod design. Its’s 4 x 4”x4”.
You can see the first design was a 1234 ‘firing’ rate and had a two bearing crankshaft- after advice from experienced steam engineers this was changed to ‘1324’ and 3 bearing crankshaft.
I was also going to use the Yorkshire Wagon type boiler- fast steaming, decent water reserves and a proven design. However it is also very heavy and would have bogged down the launch in exactly the wrong place so I’ve ditched it for a lightweight steel/copper Yarrow boiler design.
So, comments please, and I hope you enjoy looking at my designs. :embarrassed:
Greg
gondolier88
    • Coniston Regatta
Re: Fast Conical Launch Design
« Reply #1 on: November 15, 2009, 02:10:14 pm »
Some more...
gondolier88
    • Coniston Regatta
« Reply #2 on: November 15, 2009, 02:12:05 pm »
One more, compare with my hand drawn linesplan.
boatmadman
« Reply #3 on: November 15, 2009, 03:14:42 pm »
Very nice, thats some project you are looking at - hope you have BIG wallet :-))
gondolier88
    • Coniston Regatta
« Reply #4 on: November 15, 2009, 04:39:29 pm »
NOPE!!!! All will be made by myself, and i've a free barn to build it in, and I won't say how but I have something in the pipeline that may see me building launch engines for a living so building the engine for trade cost, watch this space... %)
Also, because I want it to be high speed it will be light construction and not full of thick teak and mahogany, and I also have the interest of a semi retired IT consultant in Windermere (who's barn it is) as he is a power boat fan and because there are no resident fast steam launches on the lake he is interested in coming in as joint venture- he also has space to hold it and I don't mind sharing the costs or the boat.
You'd be more than welcome to come aboard of course Ian!
Greg
kno3
« Reply #5 on: November 15, 2009, 06:07:19 pm »
Greg, that's a great project, I wish you good luck and hope you'll keep us posted about the progress.
Your boiler design is interesting, but I'm not sure I understand all details. Do you have additional drawings?
Greggy1964
« Reply #6 on: November 15, 2009, 06:28:28 pm »
NOPE!!!! All will be made by myself, and I've a free barn to build it in, and I won't say how but I have something in the pipeline that may see me building launch engines for a living so building the engine for trade cost, watch this space... Inocent
Avidly! :-))
gondolier88
    • Coniston Regatta
« Reply #7 on: November 15, 2009, 06:39:59 pm »
Hi Kno,
That's just a stock 'Yarrow boiler' image off google to show general arrangement- i've yet to do the heating surface calculations and final design, I will post it as soon as it's done.
Unless you mean the Yorkshire wagon type drawing- I just included that to show what I first considered and why I changed it to the Yarrow.
They were used by the Yorkshire Wagon Co., Leeds, they are in my eyes one of the least appreciated designs of steam boiler around- not helped by the fact I think there only around 3 left in the world!!! They are good steamers and very efficient too, also the shape allows ancilliary equipment to be slung beneath the 'wings' on either side allowing for a very compact steam plant.
Greg
kno3
« Reply #8 on: November 15, 2009, 06:42:56 pm »
Greg, I meant the Yorkshire boiler, the Yarrow I know.
gondolier88
    • Coniston Regatta
« Reply #9 on: November 15, 2009, 06:55:19 pm »
I thought you might ;)
Heres a pic of the boiler, and i've got some sectional diagrams somewhere too, i'll find them for you.
Greg
kno3
« Reply #10 on: November 15, 2009, 07:14:39 pm »
Thanks!
gondolier88
    • Coniston Regatta
« Reply #11 on: November 15, 2009, 07:41:53 pm »
 :embarrassed: Sorry thought they were for Yorkshire wagons, but the diagrams were for St. Pancras Iron Works wagons- interesting boiler design on them too... O0
Greg
Steamer
« Reply #12 on: November 26, 2009, 01:36:38 am »
OOOOH Greg.....got the juices flowing!
Damn Sexy!
When do we start? :}
West System.....their pricey but you will never regret it.
Who's software are you using?!   ............AHHHHHH too much input!   :}
We need to talk!
Steamer
« Reply #13 on: November 26, 2009, 01:38:57 am »
You want one of these!
100 HP Seabuy Triple with enough brass to make a oger grin....... :}
andywright
« Reply #14 on: November 29, 2009, 08:01:06 pm »
Looks a nice easily driven hull to me.
benjaml1
« Reply #15 on: November 29, 2009, 10:21:44 pm »
I don't like the colour...   %)
