Author Topic: Some help needed?  (Read 7857 times)
Mark47
Some help needed?
« on: November 17, 2009, 03:27:19 pm »
Does someone have a picture of a Trent lifeboat from the stern? It would be perfect if it was out of water.
I need it, just to check waterline markings.
Many thanks.
Mark
Re: Some help needed?
« Reply #1 on: November 17, 2009, 04:11:26 pm »
Here is the Windsor Runner at Poole earlier this year year. PM me with your email address if you would like the full size image file which shows mopre detail.
« Reply #2 on: November 17, 2009, 04:26:48 pm »
Full size image sent.
Mark47
« Reply #3 on: November 17, 2009, 05:49:07 pm »
Thanks Colin, just going to have alook. :-))
Mark
Mark47
« Reply #4 on: November 17, 2009, 06:06:24 pm »
That's exactly what I needed. Thank you very much Colin. Spot on mate! O0
« Reply #5 on: November 17, 2009, 06:24:36 pm »
You're very welcome Mark.
« Reply #6 on: November 17, 2009, 06:34:49 pm »
Mark47
« Reply #7 on: November 17, 2009, 08:32:56 pm »
Dont know if this will help.
http://www.modelslipway.com/photo_gallery/trentfullsize_lespagnol/index.html
Thanks DickyD,
I have these. I needed to look at what's under the water. :-))
« Reply #8 on: November 18, 2009, 11:14:18 am »
This one then.
« Reply #9 on: November 18, 2009, 11:22:24 am »
That's an interesting shot Richard as the markings on my photo clearly show only 14 and 12 and not 10 and 16. Looks like there may have been some variations as the boat in my picture shows no indication of undergoing repainting.
Mark47
« Reply #10 on: November 18, 2009, 04:47:46 pm »
The first difference is. You pic Colin is of a Trent, Dicky's is of a Tamar.
I have however noticed a difference on bow markings from boat to boat. I think I have around 150 images of Trent's and on some the 12 is positioned just above the water line. On others the 12 is positioned half across the top of the waterline.
« Reply #11 on: November 18, 2009, 04:54:04 pm »
Sorry, must have had an old moment  :embarrassed:
« Reply #12 on: November 18, 2009, 04:59:20 pm »
Different 'dry' weight of the boats?
We certainly had to take this in to account when loading aircraft of the same type.
Doug
Mark47
« Reply #13 on: November 18, 2009, 05:18:37 pm »
Mine are usually blond moments. O0
« Reply #14 on: November 18, 2009, 05:27:44 pm »
Were the boats all of the same hull construction?
Number 6
« Reply #15 on: November 18, 2009, 05:43:33 pm »
The lifeboat in the photo posted earlier is Tenbys' Tamar Class lifeboat, I should know I took it! :} Trents and Tamars are I'm pretty sure FRC construction,fibre re-enforced composite. I'm sure if that's wrong somebody will let me know. Why not contact RNLI engineering, (Mrs Durman last time I did) I am sure they could help or point in the right direction? Cheers, Dave :-))
Mark47
« Reply #16 on: November 18, 2009, 07:57:01 pm »
It's done and dusted now. All I have to do is come up with something to make the black lines that are on the water line and apply them.
« Reply #17 on: November 18, 2009, 07:59:12 pm »
« Reply #18 on: November 18, 2009, 08:13:14 pm »
Barry's Model Lettering,  COACH LINING - Self Adhesive Vinyl
http://www.modellettering.com/showProducts.asp?categorycode=05
Mark47
« Reply #19 on: November 18, 2009, 09:39:41 pm »
Colin, Dicky.
This is what I have used for the waterline and white depth markings. I'm at odds with myself whether to order some in black because all I need are 10 pieces 0.5mm thick by 2mm long 3 pieces o.5 thick 3mm long and I have no other builds planned that will use black. I'm really a grey boat builder, but thought I would do the Trent because I always fancied one from there conception. I may however do a 1:20 Tyne at some stage in the way distant future as I have a set of plans for one.
Mark
brianc
« Reply #20 on: November 18, 2009, 10:37:26 pm »
Your giving us Scots a a bad name Mark   ;D
it`s only three quid mate and you can still use it in the grey stuff....
Check out my T 23....
Trimline for the waterline...you just need to give a coat of satin varnish to take the gloss off of it.....
You can use for your T22 build :-))
Mark47
« Reply #21 on: November 18, 2009, 10:40:23 pm »
Mark47
« Reply #22 on: November 20, 2009, 04:23:55 pm »
Trimline?
http://www.cornwallmodelboats.co.uk/acatalog/trimline.html
Well I've just ordered some from Cornwall model boats. Hope it arrives the beginning of next week, (They are normally so fast, it's unbelievable).
Once that is on, then electrics through the week and hopefully I can have my first sea trials next weekend. :-))
Page created in 0.038 seconds with 21 queries.
