Good Evening,
Could i ask for some advice please. The attached picuture shows the problem which i have encountered whilst planking my boat. So far, all other planks have lain nicely againsnt the frames, however i now have one that is not. As you can see in the picture, the plank sits against the frame on the first frame at the stern and again sits nicely on the 3rd frame. However, it is quite a distance from the 2nd frame.
I am at a bit of a quandry as how to proceed. Do i just lay the rest of the planks, and then try and fill the gap with a stealer of sorts and then see if i can get it smooth using filler, or is there a different solution that i should adopt to rectify this?
Any ideas or suggestions would be greatly appreciated.
Rgds
Aidi
