Author Topic: wiring two esc's to a switch  (Read 3979 times)
lozvik
« on: November 22, 2009, 08:37:10 am »
Is it ok to wire two esc's to one on off switch
HS93 (RIP)
  • I cannot spell , tough
Re: wiring two esc's to a switch
« Reply #1 on: November 22, 2009, 08:47:31 am »
A bit more info req ,because you normally switch the power supply of to the receiver from the BEC and you only ever have ONE BEC in use at Any one time.so if its your two Mtronics you need to remove one of the red wires from the receiver plug, just get a pin lift the flap and bend back and put a bit of tape on so it can be replaced if needed in the future, it,s safer than just not switching one on.
Peter
lozvik
« Reply #2 on: November 22, 2009, 09:15:18 am »
So are u saying join both esc's to a single switch but take off middle wire to rx from one esc?
HS93 (RIP)
« Reply #3 on: November 22, 2009, 09:22:41 am »
the one you remove the wire from will not req a switch just tape it up in the off position.
Peter
lozvik
« Reply #4 on: November 22, 2009, 09:35:30 am »
Ok I'll take yr word for that then, I don't really understand it but as long as I know which wire goes where that'll do for me, lol
HS93 (RIP)
« Reply #5 on: November 22, 2009, 09:37:47 am »
dont take my word , wait for other post and take your pick. lol
Peter %%
Timo2
« Reply #6 on: November 22, 2009, 10:48:00 am »
Hi Lozvik
   To help you understand model boat  wiring go to  The ACTion  web site , and check out the Wiring Diagrams
    Eg.      http://www.action-electronics.co.uk/pdfs/Twin%20Motors.pdf
    Timo2  :-))
Page created in 0.738 seconds with 17 queries.
