Hi Mal X,
Please put up some pictures of your Magin, even if she looks terrible, that's no point, must people who have responded know what she looks like.
Changing the original floodchamber for one of your own design wasn't the smartest thing to do, as you've experienced.
It probably holds less water than the stock one and even that one was barely large enough to make her selfright.
Keep in mind, the Magin One was designed with a 700 motor and 12-14 cells, so this boat needs weight, if you go for a brushless motor and Lipo's, you'll have to add ballast to get this boat to run sensibly, and most likely extra weight on the inside of the floodchamber to get her to self-right.
As suggested, keep the motorisation mild, this hull reaches it's limits rather quick, due to the floppy material used and the design, being for the medium powered 700 motor.
The underwaterhull needs drastic modifications to be able to run as fast as a modern epoxy hull.
Regards, Jan.
