Pages: 1 2 3 4 5 6 7 [8]   Go Down
Author Topic: Friggin' in the Riggin' HMS Victory  (Read 81973 times)
JohnReid
Re: Friggin' in the Riggin' HMS Victory
« Reply #175 on: January 07, 2010, 04:52:30 pm »
Step 58
Foreyard Tackle Pendant
There are two methods for rigging these pendants.The first a method as described by Hackney is to rig them to the shrouds and is correct for harbor rig.
Tie one 7" block at the outer quarter on each side of the yard.Tie another to the foremost shroud on each side just below the futtock stave.Tie a short length of 7" rope at the yardarm with a 13" double block in the end.This line should be long enough to allow the 13" block to lie bolow the 7" block at the yard arm when it is pulled towards the shrouds.
I however used Campbell's method as described by Longridge for this as I believe that it allows for a more stable yardarm.Yardarm stability is very important as even the slightest movement when attaching the braces on one side or the other can throw out of whack all the other ropes on the yard (bunts,leeches etc...as you can see in some of my pics.)
You could overcome some of this by not having the ropes too taunt to start off with but I haven't yet figured out how to make them look good and still look like they are carrying weight (slightly bent)
Longridges description of Campbell's method is on page 242 of his book and is used more for the modelers convenience than true harbor rig.
I will diagram both methods and you can chose between the two.
JohnReid
« Reply #176 on: January 07, 2010, 07:26:38 pm »
JohnReid
« Reply #177 on: January 07, 2010, 07:46:34 pm »
Step 59
Forward Tackle Inner Tricing Line
Tie a 7" single block to the foremost lower shroud.Make a small loop in one end of a 2 1/2" rope.Lead the other end down through the block and tie it (temporarily)leaving the loop end loose from the shroud block.
JohnReid
« Reply #178 on: January 07, 2010, 08:24:59 pm »
Step 60
Foreyard Tackle
Take a 13" block and form a becket at one end and a hook at the other,tie a length of 3 1/2" rope to the becket.Engage the hook into the loop in the hanging end of the inner tricing line.Reeve a 3 1/2 " rope in a luff tackle between the hooked block and the double block on the end of the tackle pendant.Lead the end of the thread back above the hooked block,down through the loop in the end of the tricing line alongside the hook and tie off.The lower end of of the inner tricing line can now be permanently fixed.
JohnReid
« Reply #179 on: January 07, 2010, 09:21:03 pm »
JohnReid
« Reply #180 on: January 07, 2010, 09:57:31 pm »
Confused ? me too!
Let me explain:
Ropes 59 & 61 both run down the shrouds.The ? at the end of the yardarm is to indicate that this is where the outer end of the tricing line attaches to the yardarm pendant so that it can be pulled up to the yardarm.
The other ? shows where the inner tricing line pulls the yard tackle up towards the yardarm into a stowed position.
JohnReid
« Reply #181 on: January 07, 2010, 10:22:54 pm »
Step 61
Foreyard Tackle Outer Tricing Line
Tie a length of 2" rope to the tackle pendant right above the block.Pass the free end up and through the yard quarter block,across and down through the uppermost shroud block and down the shroud rope.
JohnReid
« Reply #182 on: January 08, 2010, 01:16:58 am »
JohnReid
« Reply #183 on: January 08, 2010, 04:13:42 pm »
Step 62 (This is so important that I gave it a step of its own)
Foretopsail yard
Decision time! will it be harbor,furled or sail rig? If sail rig, position this yard high on the mast,if furled or harbor rig is your preference then mount it low on the mast ,almost to the level of the caps.The same is true for the other masts as well.
Decision #2 how much rigging do I want to show on these yards? should I install it all now?(recommended)
Decision #3 see Longridge P247-48.Securely pinning or gluing down things down.On the real ship there is a lot of weight on the rigging to hold things in place,on a model the yards and the lines can work themselves lose to give your model a less than ship shape look. I know because it also happened to me.
JohnReid
« Reply #184 on: January 08, 2010, 10:20:51 pm »
JohnReid
« Reply #185 on: January 08, 2010, 10:39:43 pm »
Step 63
Foretopsail Yard Tie Purchases
The blocks installed under the crosstrees are used for these ropes.Tie two lengths of 6" rope around the head of the topmast just above the crosstrees so that one length hangs down each side.The starboard rope is lead through one sheave of the double block on the yard, through the single block under the port side of the crosstrees and down alongside the port topmast backstay.Tye in its end a 14" double block just above the level of the lower yard.Repeat the process with the port length of rope ,leading it the opposite way and finishing with its end block hanging alongside the starboard backstay.
JohnReid
« Reply #186 on: January 08, 2010, 10:59:27 pm »
Step 64
Foretopsail Yard Halyards
Tie a 14" single becket block,one each side,to the eyebolts immediately aft of the eleventh deadeyes in the fore channels by short lengths of rope,so that the blocks are just above the level of the upper deadeyes.Lengths of 3 1/2" are tied to the beckets of these blocks.Reeve them to the double blocks of the tie purchases in a luff tackle.Tie the falls inside the forecastle rail .
Step 65
Foretopgallant Yard
Locate the position of the yard on the mast just above the cap and pin and glue in position.
JohnReid
« Reply #187 on: January 09, 2010, 01:30:44 am »
JohnReid
« Reply #188 on: January 09, 2010, 01:49:53 am »
Step 66
Foretopgallant Tie
Lead a rope of 4 1/2" through the topgallant mast sheave and then down aft of the mast.Tie a 8" double block in its end slightly above the level of the foremast cap.
Step 67
Foretopgallant Yard Halyard
Tie a length of 3" rope to the becket of the remaining single block installed above the aft end of the foretop.Reeve this to the double block just installed on the foretopgallant tie in a luff tackle.Lead the fall through the aft hole in the foretop.
JohnReid
« Reply #189 on: January 09, 2010, 02:51:03 pm »
JohnReid
« Reply #190 on: January 09, 2010, 02:56:36 pm »
It is very difficult to photograph the run of the running rigging while the model is in the case due to very limited access,lighting conditions etc......I will highlight the
important parts of the tackle wherever possible. The run of the rigging should be clear in the various steps that I have described.Belaying points on deck will be fully covered and illustrated at a later stage.Cheers! John.
JohnReid
« Reply #191 on: January 15, 2010, 05:14:48 pm »
Step 68
Foreyard Lifts
Tie a 12" single block end to end with a 26" double block,attach the larger block to the to the yardarm of the foreyard.A 4 1/2" rope is attached to the becket of the block already installed at the mast cap.Lead it down through the top and inside the shrouds to belay at the kevel opposite the fore end of the fore channel.
Hack P 72
Long P242-43.
JohnReid
« Reply #192 on: January 17, 2010, 05:43:07 pm »
I will continue with this thread as soon as possible but for now I must get back to my Canada Aviation Museum commitments.Thanks for your understanding.Cheers! John.
JohnReid
« Reply #193 on: February 12, 2010, 04:04:07 pm »
I visited a couple of local hobby stores yesterday and to my surprise I saw something amazing.Ten years ago, except for the amour guys ,hardly anyone knew about dioramas or even what they were.Not only most modelers but the arts community too!
Things are finally changing,they now have craft materials for kids, even under ten years old' labeled as "diorama kits".I am not just talking about the modeling section of the stores but in the childrens craft section as well.Sure,I know that this kind of craft thing has been around for a long time but I never have seen a kit designed especially for kids and labeled a diorama.
So what is the big deal?Well maybe sometime in the future makers of dioramas will not have to explain to 9 out of 10 people that they meet what kind of art they do.
Pages: 1 2 3 4 5 6 7 [8]   Go Up
Page created in 0.029 seconds with 19 queries.
